Датчик температуры DHT11 и TM1637
SlawonK
19 Янв 2020
Посмотретите пожалуйста почему не рабоет код
#include <DHT.h>
#include <DHT_U.h>
#include <TM1637.h>
#define DHTPIN 2
#define DHTTYPE DHT11
#define CLK 9
#define DIO 8
TM1637 tm1637 (CLK,DIO);
DHT dht(DHTPIN, DHTTYPE);
tm1637.init();
tm1637.set(BRIGHT_TYPICAL);
delay(1500);
dht.read(DHTPIN);
int temp = dht.temperature;
int humidity = dht.humidity;
int digitoneT = temp / 10;
int digittwoT = temp % 10;
int digitoneH = humidity / 10;
int digittwoH = humidity % 10;
tm1637.display(1.digitoneT);
tm1637.display(2.digitwoT);
tm1637.display(3.12);
delay (5000);
tm1637.display(1.digitoneH);
tm1637.display(2.digitwoH);
tm1637.display(3.15);
Выдает ошибку:
C:\Users\User\Documents\DT11\DT11.ino: In function 'void loop()':
DT11:29:18: error: 'class DHT' has no member named 'temperature'
DT11:30:22: error: 'class DHT' has no member named 'humidity'
DT11:38:18: error: unable to find numeric literal operator 'operator""digitoneT'
DT11:39:18: error: unable to find numeric literal operator 'operator""digitwoT'
DT11:40:22: error: no matching function for call to 'TM1637::display(double)'
In file included from C:\Users\User\Documents\DT11\DT11.ino:3:0:
C:\Program Files (x86)\Arduino\libraries\TM1637/TM1637.h:51:10: note: candidate: void TM1637::display(int8_t*)
void display(int8_t DispData[]);
C:\Program Files (x86)\Arduino\libraries\TM1637/TM1637.h:51:10: note: no known conversion for argument 1 from 'double' to 'int8_t* {aka signed char*}'
C:\Program Files (x86)\Arduino\libraries\TM1637/TM1637.h:52:10: note: candidate: void TM1637::display(uint8_t, int8_t)
void display(uint8_t BitAddr,int8_t DispData);
C:\Program Files (x86)\Arduino\libraries\TM1637/TM1637.h:52:10: note: candidate expects 2 arguments, 1 provided
DT11:44:18: error: unable to find numeric literal operator 'operator""digitoneH'
DT11:45:18: error: unable to find numeric literal operator 'operator""digitwoH'
DT11:46:22: error: no matching function for call to 'TM1637::display(double)'
exit status 1
1,324
Возможно обращаться надо не как к полям, а как к методам, т.е. функциям, тогда вместо
следует писать
nt temp = dht.temperature();
int humidity = dht.humidity();
такая ошибка распространенная. Что бы проверить надо ставить библиотеки, пока это не удобно делать
