esp32(&s3) + rtc ds3231 как передать библиотеке Time.h данные из часов ?
SlavaZagaynov
27 Ноя 2019
134
28
www.youtube.com
есть такой типовой пример в ардуине
#include <WiFi.h>
#include "time.h"
#include "sntp.h"
const char* ssid = "YOUR_SSID";
const char* password = "YOUR_PASS";
const char* ntpServer1 = "pool.ntp.org";
const char* ntpServer2 = "time.nist.gov";
const long gmtOffset_sec = 3600;
const int daylightOffset_sec = 3600;
const char* time_zone = "CET-1CEST,M3.5.0,M10.5.0/3"; // TimeZone rule for Europe/Rome including daylight adjustment rules (optional)
void printLocalTime()
struct tm timeinfo;
if(!getLocalTime(&timeinfo)){
Serial.println("No time available (yet)");
return;
Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S");
// Callback function (get's called when time adjusts via NTP)
void timeavailable(struct timeval *t)
Serial.println("Got time adjustment from NTP!");
printLocalTime();
void setup()
// set notification call-back function
sntp_set_time_sync_notification_cb( timeavailable );
* NTP server address could be aquired via DHCP,
* NOTE: This call should be made BEFORE esp32 aquires IP address via DHCP,
* otherwise SNTP option 42 would be rejected by default.
* NOTE: configTime() function call if made AFTER DHCP-client run
* will OVERRIDE aquired NTP server address
sntp_servermode_dhcp(1); // (optional)
* This will set configured ntp servers and constant TimeZone/daylightOffset
* should be OK if your time zone does not need to adjust daylightOffset twice a year,
* in such a case time adjustment won't be handled automagicaly.
configTime(gmtOffset_sec, daylightOffset_sec, ntpServer1, ntpServer2);
* A more convenient approach to handle TimeZones with daylightOffset
* would be to specify a environmnet variable with TimeZone definition including daylight adjustmnet rules.
* A list of rules for your zone could be obtained from https://github.com/esp8266/Arduino/blob/master/cores/esp8266/TZ.h
//configTzTime(time_zone, ntpServer1, ntpServer2);
//connect to WiFi
Serial.printf("Connecting to %s ", ssid);
WiFi.begin(ssid, password);
delay(500);
Serial.print(".");
Serial.println(" CONNECTED");
void loop()
delay(5000);
printLocalTime(); // it will take some time to sync time :)
Может кто подсказать как сказать библиотеке "time.h", которая сама умеет считать время, уже известное время от часов?
(Суть такая ... есп включилась, получила время с часов, далее если есть интернет - обновила внутреннее время и время на часах.)
968
@SlavaZagaynov, попробуйте переформулировать вопрос. Пока совершенно непонятно, что собственно нужно? Если вас интересует получение времени из инета в локальное время - смотрите свой собственный пример.
