Определение влажности почвы
Asura
16 Дек 2018
Добрый день нашел код для esp8266 для проверки влажности почвы через интернет используя этот датчик но никак не могу разобраться как изменить код под этот датчик
/* ESP8266 Moisture Sensor
This sketch uses an ESP8266 to read the analog signal from a moisture sensor. The data is then displayed
using the serial console or a web browser. Based on the moisture reading, the ESP8266 will blink a RGB LED
red, green or blue.
Red = Dry
Green = In between Wet and Dry
Blue = Wet
Viewing the data via web browser by going to the ip address. In this sketch the address is
http://192.168.1.221
The browser data includes a Google Chart to visually illustrate the moisture reading as a guage.
Arduino IDE Setup
File:
Preferences
Add the following link to the "Additional Boards Manager URLs" field:
http://arduino.esp8266.com/stable/package_esp8266com_index.json
Tools:
board: NodeMCU 1.0 (ESP-12 Module)
programmer: USBtinyISP
#include <ESP8266WiFi.h>
const char* ssid = "";
const char* password = "";
const int redPin = 4; // ~D2
const int greenPin = 12; // ~D6
const int bluePin = 14; // ~D5
int WiFiStrength = 0;
WiFiServer server(80);
delay(10);
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
// color while waiting to connect
analogWrite(redPin, 280);
analogWrite(greenPin, 300);
analogWrite(bluePin, 300);
// Connect to WiFi network
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
// Set the ip address of the webserver
// WiFi.config(WebServerIP, Gatway, Subnet)
// or comment out the line below and DHCP will be used to obtain an IP address
// which will be displayed via the serial console
WiFi.config(IPAddress(192, 168, 1, 221), IPAddress(192, 168, 1, 1), IPAddress(255, 255, 255, 0));
// connect to WiFi router
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Start the server
server.begin();
Serial.println("Server started");
// Print the IP address
Serial.print("Use this URL to connect: ");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.println("/");
double analogValue = 0.0;
double analogVolts = 0.0;
unsigned long timeHolder = 0;
WiFiStrength = WiFi.RSSI(); // get dBm from the ESP8266
analogValue = analogRead(A0); // read the analog signal
// convert the analog signal to voltage
// the ESP2866 A0 reads between 0 and ~3 volts, producing a corresponding value
// between 0 and 1024. The equation below will convert the value to a voltage value.
analogVolts = (analogValue * 3.08) / 1024;
// now get our chart value by converting the analog (0-1024) value to a value between 0 and 100.
// the value of 400 was determined by using a dry moisture sensor (not in soil, just in air).
// When dry, the moisture sensor value was approximately 400. This value might need adjustment
// for fine tuning of the chartValue.
int chartValue = (analogValue * 100) / 400;
// now reverse the value so that the value goes up as moisture increases
// the raw value goes down with wetness, we want our chart to go up with wetness
chartValue = 100 - chartValue;
// set a "blink" time interval in milliseconds.
// for example, 15000 is 15 seconds. However, the blink will not always be 15 seconds due to other
// delays set in the code.
if (millis() - 15000 > timeHolder)
timeHolder = millis();
// determine which color to use with the LED based on the chartValue.
// note: PWM is used so any color combo desired can be set by changing the values sent to each pin
// between 0 and 1024 - 0 being OFF and 1024 being full power
//// yellowish
// analogWrite(redPin, 900);
// analogWrite(greenPin, 1010);
// analogWrite(bluePin, 100);
if (chartValue <= 25) { // 0-25 is red "dry"
analogWrite(redPin, 1000);
analogWrite(greenPin, 0);
analogWrite(bluePin, 0);
} else if (chartValue > 25 && chartValue <= 75) // 26-75 is green
analogWrite(redPin, 0);
analogWrite(greenPin, 1000);
else if (chartValue > 75 ) // 76-100 is blue
analogWrite(bluePin, 1000);
delay(1000); // this is the duration the LED will stay ON
// Serial data
Serial.print("Analog raw: ");
Serial.println(analogValue);
Serial.print("Analog V: ");
Serial.println(analogVolts);
Serial.print("ChartValue: ");
Serial.println(chartValue);
Serial.print("TimeHolder: ");
Serial.println(timeHolder);
Serial.print("millis(): ");
Serial.println(millis());
Serial.print("WiFi Strength: ");
Serial.print(WiFiStrength); Serial.println("dBm");
Serial.println(" ");
delay(1000); // slows amount of data sent via serial
// check to for any web server requests. ie - browser requesting a page from the webserver
WiFiClient client = server.available();
if (!client) {
return;
// Wait until the client sends some data
Serial.println("new client");
// Read the first line of the request
String request = client.readStringUntil('\r');
Serial.println(request);
client.flush();
// Return the response
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println(""); // do not forget this one
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println(" <head>");
client.println("<meta http-equiv=\"refresh\" content=\"60\">");
client.println(" <script type=\"text/javascript\" src=\"https://www.gstatic.com/charts/loader.js\"></script>");
client.println(" <script type=\"text/javascript\">");
client.println(" google.charts.load('current', {'packages':['gauge']});");
client.println(" google.charts.setOnLoadCallback(drawChart);");
client.println(" function drawChart() {");
client.println(" var data = google.visualization.arrayToDataTable([ ");
client.println(" ['Label', 'Value'], ");
client.print(" ['Moisture', ");
client.print(chartValue);
client.println(" ], ");
client.println(" ]); ");
// setup the google chart options here
client.println(" var options = {");
client.println(" width: 400, height: 120,");
client.println(" redFrom: 0, redTo: 25,");
client.println(" yellowFrom: 25, yellowTo: 75,");
client.println(" greenFrom: 75, greenTo: 100,");
client.println(" minorTicks: 5");
client.println(" };");
client.println(" var chart = new google.visualization.Gauge(document.getElementById('chart_div'));");
client.println(" chart.draw(data, options);");
client.println(" setInterval(function() {");
client.print(" data.setValue(0, 1, ");
client.println(" );");
client.println(" }, 13000);");
client.println(" }");
client.println(" </script>");
client.println(" </head>");
client.println(" <body>");
client.print("<h1 style=\"size:12px;\">ESP8266 Soil Moisture</h1>");
// show some data on the webpage and the guage
client.println("<table><tr><td>");
client.print("WiFi Signal Strength: ");
client.println(WiFiStrength);
client.println("dBm<br>");
client.print("Analog Raw: ");
client.println(analogValue);
client.print("<br>Analog Volts: ");
client.println(analogVolts);
client.println("<br><a href=\"/REFRESH\"\"><button>Refresh</button></a>");
client.println("</td><td>");
// below is the google chart html
client.println("<div id=\"chart_div\" style=\"width: 300px; height: 120px;\"></div>");
client.println("</td></tr></table>");
client.println("<body>");
client.println("</html>");
delay(1);
Serial.println("Client disonnected");
Serial.println("");
