ARDUINO предупреждение компилятора
stepan_sotnikov
19 Май 2019
В целях обучения написала программку обработки данных с акселерометра/гироскопа магнитометра.
Программа работает как надо, но компилятор выдерет предупреждения.
C:\Users\user\Documents\Arduino\compas_1.2.1\compas_1.2.1.ino: In function 'boolean readMag(int16_t*, int16_t*, int16_t*)': C:\Users\user\Documents\Arduino\compas_1.2.1\compas_1.2.1.ino:96:35: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second: Wire.requestFrom(Adres_for_Mg, 7); ^ In file included from C:\Users\user\Documents\Arduino\compas_1.2.1\compas_1.2.1.ino:28:0: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src/Wire.h:64:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int) uint8_t requestFrom(int, int); ^ C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src/Wire.h:61:13: note: candidate 2: uint8_t TwoWire::requestFrom(uint8_t, uint8_t) uint8_t requestFrom(uint8_t, uint8_t); ^ C:\Users\user\Documents\Arduino\compas_1.2.1\compas_1.2.1.ino: In function 'boolean readAccGir(int16_t*, int16_t*, int16_t*, int16_t*, int16_t*, int16_t*, int16_t*)': C:\Users\user\Documents\Arduino\compas_1.2.1\compas_1.2.1.ino:112:44: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second: Wire.requestFrom(Adres_for_AcGy, 14, true); ^ In file included from C:\Users\user\Documents\Arduino\compas_1.2.1\compas_1.2.1.ino:28:0: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src/Wire.h:65:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int, int) uint8_t requestFrom(int, int, int); ^ C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src/Wire.h:62:13: note: candidate 2: uint8_t TwoWire::requestFrom(uint8_t, uint8_t, uint8_t) uint8_t requestFrom(uint8_t, uint8_t, uint8_t); ^
Не знаю как решить эту задачу, не хватает знаний.
stepan_sotnikov
19 Май 2019
сам код
/*Учебная программа. Работа с магнитометром и гироскопом акселерометром:
MPU6050 даташит:https://www.invensense.com/wp-content/uploads/2015/02/MPU-6000-Register-Map1.pdf
QMC5883 даташит:https://img.filipeflop.com/files/download/Datasheet-QMC5883L-1.0%20.pdf
Для корректировки данных с магнитометра используется матрица трансформации.
Коэффициенты получены обработкой сырых данных в Magneto ver. 1.2
подсмотрел тут:
http://www.germersogorb.de/html/kalibrierung_des_hcm5883l.html
http://robotclass.ru/articles/magnetometer-and-compass/
https://sites.google.com/site/diyheadtracking/home/kalibrovka-sensorov/magnetometr-calibration
http://www.count-zero.ru/2016/hmc5883l/
Для гироскопа  коэффициенты дрейфа рассчитываются программно в setup() {}
функцией Corect_fo_Ac() на основании 1000 измерений.
Для данных магнитометра по осям X;Y применен фильтр Калмана.
Для корректировки данных с акселерометра применен комплементарный фильтр с опорой на данные с акселерометра.
В результате работы программы получаем данные отклонения в градусах от направления на магнитный полюс, и от горизонта, где 0 горизонт.
ATmega328P  Arduino Uno
Скетч использует 8824 байт (27%) памяти устройства. Всего доступно 32256 байт.
Глобальные переменные используют 522 байт (25%) динамической памяти, оставляя 1526 байт для локальных переменных. Максимум: 2048 байт.
______________________
Stepan_Sotnikov
#include <Wire.h>
//#include <Servo.h>
// Servo myservo;
//настройка Акселерометра гироскопа
const uint8_t Adres_for_AcGy = 0x68;  // MPU6050
const uint8_t Reg_of_AcGy_PWR_MGMT = 0x6B;  //регистр управления питание
const uint8_t RD_of_AcGy = 0x3B;  //  0x3B (ACCEL_XOUT_H)
//настройка магнитометра
const uint8_t Adres_for_Mg = 0x0D;  // QMC5883
const uint8_t Reg_of_Mg_Set_Reset = 0x0B;  //регистр управления настройками
const uint8_t REG_CONTROL_of_Mg = 0x09;
const uint8_t RD_of_Mg = 0x00;
const float TO_Degrees = 57.2958;
const float TO_Radians = 0.01745;
//const float Pi = 3.14159;
//поправки дрейфа акс.
static int16_t Corect_fo_Ac_X;  //=144;
static int16_t Corect_fo_Ac_Y;  //=-145;
static int16_t Corect_fo_Ac_Z;  //=251;
//переменные для функции calculate
static int16_t MGx, MGy, MGz, AcX, AcY, AcZ, Tmp, GyX, GyY, GyZ;
static float deltaTimer = 0.0;
static float Gy_roll_X = 0;
static float Gy_roll_Y = 0;
static float Gy_roll_Z = 0;
static uint32_t timer;
static float azimuth;
//коэффициент перехода от сырых данных гироскопа,
const float Transform_Gy_roll_to_Deg = 0.00763;  // 1/131
const float Gy_roll_camp_fo_Z = 0.01;            // коэф камп
const float Gy_roll_camp_fo_XY = 0.01;  //кохф камп для осей X Y
void initMagnetometr() {  //функция иниц. магн.
  Wire.begin();
  Wire.beginTransmission(Adres_for_Mg);
  Wire.write(Reg_of_Mg_Set_Reset);
  Wire.write(0b00000001);  //
  Wire.endTransmission(true);
  Wire.write(REG_CONTROL_of_Mg);
  Wire.write(0b00011101);  // Mode_Continuous,ODR_200Hz,RNG_8G,OSR_512
void initAccelgyro() {  //функция иниц. магн.
  Wire.begin();
  Wire.beginTransmission(Adres_for_AcGy);
  Wire.write(Reg_of_AcGy_PWR_MGMT);
  Wire.write(0b00000000);
//чтение данных маг.
boolean readMag(int16_t* MGx, int16_t* MGy, int16_t* MGz) {
  Wire.write(RD_of_Mg);
  int err = Wire.endTransmission();
  if (err) {
    return false;
  *MGx = (Wire.read() | Wire.read() << 8);
  *MGy = (Wire.read() | Wire.read() << 8);
  *MGz = (Wire.read() | Wire.read() << 8);
  return true;
boolean readAccGir(int16_t* AcX, int16_t* AcY, int16_t* AcZ, int16_t* Tmp,
                   int16_t* GyX, int16_t* GyY, int16_t* GyZ) {
  Wire.write(RD_of_AcGy);
  Wire.endTransmission(false);
  if (err) {
    return false;
  *AcX = Wire.read() << 8 | Wire.read();
  *AcY = Wire.read() << 8 | Wire.read();
  *AcZ = Wire.read() << 8 | Wire.read();
  *Tmp = Wire.read() << 8 | Wire.read();
  *GyY = Wire.read() << 8 | Wire.read();//зависит от взаиморасположение датчиков
  *GyX = Wire.read() << 8 | Wire.read();
  *GyZ = Wire.read() << 8 | Wire.read();
  return true;
void Corect_fo_Ac(int16_t* Corect_fo_Ac_X, int16_t* Corect_fo_Ac_Y,
                  int16_t* Corect_fo_Ac_Z) {
  long f_fo_GyX = 0;
  long f_fo_GyY = 0;
  long f_fo_GyZ = 0;
  for (int i = 0; i < 1000; i++) {
    //читаем сырые данные из гироакселерометра
    readAccGir(&AcX, &AcY, &AcZ, &Tmp, &GyX, &GyY, &GyZ);
    f_fo_GyX = f_fo_GyX + GyX;
    f_fo_GyY = f_fo_GyY + GyY;
    f_fo_GyZ = f_fo_GyZ + GyZ;
  *Corect_fo_Ac_X = (int16_t)(-f_fo_GyX / 1000);
  *Corect_fo_Ac_Y = (int16_t)(-f_fo_GyY / 1000);
  *Corect_fo_Ac_Z = (int16_t)(-f_fo_GyZ / 1000);
//функция калибровки данных магнитметра
 void calibrate(int16_t* MGx, int16_t* MGy, int16_t* MGz) {
  float calibr_matrix[3][3] = {{ 1.117512, -0.032663,  0.003151},
                               {-0.032663, 1.095694, -0.034088},
                               { 0.003151, -0.034088,  1.102701}};
  float CombBias[3] = {       -241.661816, -373.203215, 41.251631};
  float val[3];
  val[0] = *MGx;
  val[1] = *MGy;
  val[2] = *MGz;
  for (uint8_t i = 0; i < 3; ++i) {  //умножения матриц
    val[i] = val[i] - CombBias[i];
  float result[3] = {0, 0, 0};
    for (uint8_t j = 0; j < 3; ++j) {
      result[i] += calibr_matrix[i][j] * val[j];
    val[i] = result[i];
  *MGx = (int16_t)val[0];
  *MGy = (int16_t)val[1];
  *MGz = (int16_t)val[2];
// переменные для Калмана
// скорость реакции на изменение (подбирается вручную) для 2 фильтров
float varProcess = 0.1;
float varVoltX = 7.80255;  //среднее отклонение вычисляем из опыта
float PcX = 0.0, GX = 0.0, PX = 1.0, XpX = 0.0, ZpX = 0.0, XeX = 0.0;
// переменные для Калмана X
// Функция фильтрации
int16_t filterKalmanX(int16_t valX) {// Функция фильтрации
  PcX = PX + varProcess;
  GX = PcX / (PcX + varVoltX);
  PX = (1 - GX) * PcX;
  XpX = XeX;
  ZpX = XpX;
  XeX = GX * ((float)valX - ZpX) + XpX;
  return (int16_t)(XeX);
// переменные для Калмана Y
float varVoltY = 13.29522;  // среднее отклонение вычисляем из опыта
float PcY = 0.0, GY = 0.0, PY = 1.0, XpY = 0.0, ZpY = 0.0, XeY = 0.0;
int16_t filterKalmanY(int16_t valY) {  // Функция фильтрации
  PcY = PY + varProcess;
  GY = PcY / (PcY + varVoltY);
  PY = (1 - GY) * PcY;
  XpY = XeY;
  ZpY = XpY;
  XeY = GY * ((float)valY - ZpY) + XpY;
  return (int16_t)(XeY);
void calculate() {
  //трансформируем данные магнитометра согласно калибр. матри.
  calibrate(&MGx, &MGy, &MGz);
  //фильтруем данные маг.
  MGx = filterKalmanX(MGx);
  MGy = filterKalmanY(MGy);
  //вычисляем углы наклона по акс.
  float Ac_roll_X = atan(((float)(AcX)) / ((float)(AcZ))) * TO_Degrees;
  float Ac_roll_Y = atan(((float)(AcY)) / ((float)(AcZ))) * TO_Degrees;
  //вычисляем углы по гиро.
  Gy_roll_X -= (float)(GyX + Corect_fo_Ac_X) * deltaTimer *
               Transform_Gy_roll_to_Deg;  //здесь внимательно следить за +/-
  Gy_roll_Y += (float)(GyY + Corect_fo_Ac_Y) * deltaTimer *
               Transform_Gy_roll_to_Deg;  //зависит от взаиморасположения датчиков
  Gy_roll_Z -= (float)(GyZ + Corect_fo_Ac_Z) * deltaTimer *
  //Получаем углы вращения по гироакселеромету
  //вычисл. параметры наклонов A=A*(1-k)+B*(k)
  //где к-коэф. А-корректируемой значение, В-корректировочное значения
  Gy_roll_X = Gy_roll_X * (1 - Gy_roll_camp_fo_XY) +
              Ac_roll_X * (Gy_roll_camp_fo_XY);  // внимательно смотрим как
                                                 // расположены между собой
                                                 // датчики
  Gy_roll_Y = Gy_roll_Y * (1 - Gy_roll_camp_fo_XY) +
              Ac_roll_Y * (Gy_roll_camp_fo_XY);  //
  float SINx = sin(Gy_roll_X * TO_Radians);
  float COSx = cos(Gy_roll_X * TO_Radians);
  float SINy = sin(Gy_roll_Y * TO_Radians);
  float COSy = cos(Gy_roll_Y * TO_Radians);
  //доворачиваем вектор МП до положение датчика
  MGx = (int16_t)((float)MGx * COSy +
                  (float)MGy * SINx * SINy +
                  (float)MGz * COSx * SINy);
  MGy = (int16_t)((float)MGy * COSx - (float)MGz * SINx);
  //по превед. вектору вычисляем отклонение оси Х от Направление на север
  //получили +/- отклонения Х от направ. на маг.Север
  azimuth = atan2((float)MGy, (float)MGx) * TO_Degrees;
  // значение Gy_roll_Z-azimuth подбирается из расчета скорости реакции
  if (abs(Gy_roll_Z - azimuth) > 15) {
    Gy_roll_Z = azimuth;
  //на случай критического отставания
  Gy_roll_Z =
      Gy_roll_Z * (1 - Gy_roll_camp_fo_Z) + azimuth * (Gy_roll_camp_fo_Z);
  if (Gy_roll_Z < 0) {
    azimuth += 360;
  initMagnetometr();  //инициализация магн.
  initAccelgyro();    //инициализация гиро.
  //вычисляем дрейф гироскопа
  Corect_fo_Ac(&Corect_fo_Ac_X, &Corect_fo_Ac_Y, &Corect_fo_Ac_Z);
  Wire.begin();
  Serial.begin(230400);
  //инициализация серво.
  // myservo.attach(9);
  // myservo.write(0);
  timer = micros();
  readMag(&MGx, &MGy, &MGz);  //читаем сырые данные из магнитометра
  calculate();  //пересчитываем полученные данные
  // int G=(int)(-Gy_roll_Z+90);
  // myservo.write(G);
  //выводм данные
  Serial.print(" ");
  Serial.print(Gy_roll_X);
  Serial.print(" ");
  Serial.print(Gy_roll_Y);
  Serial.print(" ");
  Serial.print(Gy_roll_Z);
  // Serial.print(" ");
  // Serial.print(azimuth);
  // Serial.print(" ");*/
  Serial.println(" ");
  deltaTimer =
      (float)(micros() - timer) / 1000000.0;  //получаем время между измерениями
