ARDUINO Проблема с GyverHacks и GyverRGB на Ardoino ProMicro
SashaPetrov
22 Май 2019
31
Пытаюсь получить шим на 2пине с помощью библиотек.
Для GyverHacks выдаёт:
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp: In function 'void setPWMmode(byte, byte)':
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:167:13: error: 'TCCR2A' was not declared in this scope
if (mode) TCCR2A |= _BV(WGM20);
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:167:13: note: suggested alternative: 'TCCR0A'
TCCR0A
In file included from c:\users\�����\documents\arduinodata\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5\avr\include\avr\io.h:99:0,
from c:\users\�����\documents\arduinodata\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5\avr\include\avr\pgmspace.h:90,
from C:\Users\�����\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.2\cores\arduino/Arduino.h:28,
from C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.h:3,
from C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:1:
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:167:27: error: 'WGM20' was not declared in this scope
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:167:27: note: suggested alternative: 'WGM40'
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:168:8: error: 'TCCR2A' was not declared in this scope
else TCCR2A |= _BV(WGM20) | _BV(WGM21);
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:168:8: note: suggested alternative: 'TCCR0A'
TCCR0A
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:168:22: error: 'WGM20' was not declared in this scope
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:168:22: note: suggested alternative: 'WGM40'
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:168:35: error: 'WGM21' was not declared in this scope
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:168:35: note: suggested alternative: 'WGM41'
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp: In function 'void setPWMprescaler(uint8_t, uint16_t)':
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:224:2: error: 'TCCR2B' was not declared in this scope
TCCR2B = 0;
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:224:2: note: suggested alternative: 'TCCR0B'
TCCR2B = 0;
TCCR0B
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp: In function 'void setPWM(uint8_t, uint16_t)':
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:294:7: error: 'TCCR2A' was not declared in this scope
sbi(TCCR2A, COM2B1);
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:294:3: note: in expansion of macro 'sbi'
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:294:7: note: suggested alternative: 'TCCR0A'
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:294:15: error: 'COM2B1' was not declared in this scope
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:294:15: note: suggested alternative: 'COM1B1'
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:295:3: error: 'OCR2B' was not declared in this scope
OCR2B = duty;
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:295:3: note: suggested alternative: 'OCR4B'
OCR2B = duty;
OCR4B
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:298:15: error: 'COM2A1' was not declared in this scope
sbi(TCCR2A, COM2A1);
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:298:3: note: in expansion of macro 'sbi'
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:298:15: note: suggested alternative: 'COM0A1'
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:299:3: error: 'OCR2A' was not declared in this scope
OCR2A = duty;
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:299:3: note: suggested alternative: 'OCR3A'
OCR2A = duty;
OCR3A
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp: In function 'void anyPWMinit(byte)':
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:314:3: error: 'TCCR2A' was not declared in this scope
TCCR2A = 0; //при совпадении уровень OC1A меняется на противоположный
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:314:3: note: suggested alternative: 'TCCR0A'
TCCR0A
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:315:3: error: 'TCCR2B' was not declared in this scope
TCCR2B = 5; //CLK
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:315:3: note: suggested alternative: 'TCCR0B'
TCCR2B = 5; //CLK
TCCR0B
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:316:3: error: 'OCR2A' was not declared in this scope
OCR2A = 1;
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:316:3: note: suggested alternative: 'OCR3A'
OCR2A = 1;
OCR3A
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:317:3: error: 'TIMSK2' was not declared in this scope
TIMSK2 = 2; //разрешаем прерывание по совпадению
C:\Arduino\Nano\libraries\GyverHacks\GyverHacks.cpp:317:3: note: suggested alternative: 'TIMSK0'
TIMSK0
exit status 1
Ошибка компиляции для платы Arduino Leonardo.
Для RGB:
C:\Users\7272~1\AppData\Local\Temp\ccKYCMe6.ltrans0.ltrans.o: In function `setRGB':
C:\Arduino\Nano\libraries\GyverRGB/GyverRGB.cpp:427: undefined reference to `pwmWrite(unsigned char, unsigned char)'
C:\Arduino\Nano\libraries\GyverRGB/GyverRGB.cpp:428: undefined reference to `pwmWrite(unsigned char, unsigned char)'
C:\Arduino\Nano\libraries\GyverRGB/GyverRGB.cpp:429: undefined reference to `pwmWrite(unsigned char, unsigned char)'
collect2.exe: error: ld returned 1 exit status
exit status 1
ruslanin
12 Фев 2020
Эх, и под ESP8266 тоже не получается использовать GyverRGB
