// include the library code:
#include <LiquidCrystal.h>
#include <OneWire.h>
OneWire ds(10);
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// RS , E , D4 , D5 , D6 , D7
int i, j, n, m;
// initialize display
// 3rd parameter is a string containing some needed russian characters from "БГДЖЗИЙЛПУФЦЧШЩЬЪЫЭЮЯ"
// up to 16 letters, but recommended not more than 8, anyway, i can use 16 on my lcd :)
static byte addon_letters[16];
void init_rus(const char* letters_use )
// custom characters
static byte letters[][8] = {
{ B11111, B10000, B10000, B11111, B10001, B10001, B11111, B00000 },//Б
{ B11111, B10000, B10000, B10000, B10000, B10000, B10000, B00000 },//Г
{ B00000, B01111, B01001, B01001, B01001, B01001, B11111, B10001 },//Д
{ B01010, B00000, B11111, B10000, B11110, B10000, B10000, B11111 }, //Ё
{ B10101, B10101, B10101, B01110, B10101, B10101, B10101, B00000 },//Ж
{ B01110, B10001, B00001, B00110, B00001, B10001, B01110, B00000 },//З
{ B10001, B10001, B10011, B10101, B11001, B10001, B10001, B00000 },//И
{ B10101, B10101, B10011, B10101, B11001, B10001, B10001, B00000 },//Й
{ B00111, B01001, B10001, B10001, B10001, B10001, B10001, B00000 },//Л
{ B11111, B10001, B10001, B10001, B10001, B10001, B10001, B00000 },//П
{ B10001, B10001, B10001, B01111, B00001, B10001, B01110, B00000 },//У
{ B00000, B01110, B10101, B10101, B10101, B01110, B00100, B00100 },//Ф
{ B10001, B10001, B10001, B10001, B10001, B10001, B11111, B00001 },//Ц
{ B10001, B10001, B10001, B01111, B00001, B00001, B00001, B00000 },//Ч
{ B00000, B10101, B10101, B10101, B10101, B10101, B10101, B11111 },//Ш
{ B10101, B10101, B10101, B10101, B10101, B10101, B11111, B00001 },//Щ
{ B00000, B10000, B10000, B10000, B11110, B10001, B10001, B11110 },//Ь
{ B11000, B01000, B01110, B01001, B01001, B01001, B01110, B00000 },//Ъ
{ B10001, B10001, B10001, B11101, B10101, B10101, B11101, B00000 },//Ы
{ B00000, B11110, B00001, B00001, B01111, B00001, B00001, B11110 },//Э
{ B10111, B10101, B10101, B11101, B10101, B10101, B10111, B00000 },//Ю
{ B01111, B10001, B10001, B01111, B10001, B10001, B10001, B00000 },//Я
static char chars[] = {'Б', 'Г', 'Д', 'Ё', 'Ж', 'З', 'И', 'Й', 'Л', 'П', 'У', 'Ф', 'Ц', 'Ч', 'Ш', 'Щ', 'Ь', 'Ъ', 'Ы', 'Э', 'Ю', 'Я'};
static byte empty[8] = { 0, 0, 0, 0, 0, 0, 0, 0 };
int index = 0, cl = sizeof(chars) / sizeof(char), i, j, symb;
memset(addon_letters, 0, sizeof(addon_letters));
for ( j = 0; j < strlen(letters_use) && j < 16; j++ )
lcd.createChar(j, empty);
symb = -1;
for ( i = 0; i < cl; i++ ) if ( chars[i] == letters_use[j] ) {
symb = i;
addon_letters[index] = letters_use[j];
break;
if ( symb != -1 ) {
lcd.createChar(index, letters[symb]);
index++;
// print russian chars
void print_rus(char *str) {
static char rus_letters[] = {'А', 'Б', 'В', 'Г', 'Д', 'Е', 'Ё', 'Ж', 'З', 'И', 'Й', 'К', 'Л', 'М', 'Н', 'О', 'П', 'Р', 'С', 'Т', 'У', 'Ф', 'Х', 'Ц', 'Ч', 'Ш', 'Щ', 'Ъ', 'Ы', 'Ь', 'Э', 'Ю', 'Я' };
static char trans_letters[] = {'A', 0x80, 'B', 0x92, 0x81, 'E', 0xCB, 0x82, 0x83, 0x84, 0x85, 'K', 0x86, 'M', 'H', 'O', 0x87, 'P', 'C', 'T', 0x88, 0xA2, 'X', 0x89, 0x8A, 0x8B, 0x8C, 0x8D, 0x8E, 0x62, 0x8F, 0xAC, 0xAD};
int lcount = sizeof(rus_letters) / sizeof(char), i, j;
for ( i = 0; i < strlen(str); i++ )
if ( byte(str[i]) == 208 ) continue; // 208 ignore
int found = 0;
for (j = 0; j < 16; j++) if ( addon_letters[j] != 0 && byte(str[i]) == byte(addon_letters[j]) ) {
lcd.write(j);
found = 1;
break;
if (!found) for (j = 0; j < lcount; j++) if ( byte(str[i]) == byte(rus_letters[j]) ) {
lcd.write(trans_letters[j]);
found = 1;
break;
if (!found) lcd.write(byte(str[i]));
void print_rus(int x, int y, char *str) {
lcd.setCursor(x, y);
print_rus(str);
static byte degree[8] = { B01100, B10010, B10010, B01100, B00000, B00000, B00000, B00000 };// Значок градуса
lcd.begin(20, 4); // Задаём режим работы индикатора: 4 строки по 20 символов
lcd.command(1); //очистка дисплея команда 4-4-1
lcd.command(12); // включить дисплей
// Команды не нужны, работает без них
init_rus("ДЭШЩФЬЁ"); // Загружаем нужные символы в программируемые ячейки (максимум 8 символов)
lcd.createChar(7, degree);
print_rus(0, 0, "ТЕМПЕРАТУРА:20.6 С");
print_rus(0, 1, "1234567890()+-={}[]/");
print_rus(0, 2, "АБВГДЕЁЖЗИЙКЛМНОПРСТ");
print_rus(0, 3, "УФХЦЧШЩЪЫЬЭЮЯ");
lcd.setCursor(19, 3);
lcd.write(0xa4);
byte data[2];
ds.reset();
ds.write(0xCC);
ds.write(0x44);
//delay(750);
ds.reset();
ds.write(0xCC);
ds.write(0xBE);
data[0] = ds.read();
data[1] = ds.read();
int Temp = (data[1] << 8) + data[0];
Temp = Temp >> 4;
// lcd.setCursor(12,0);
// lcd.print(Temp);
// lcd.write(7);
// lcd.print("C ");
for (m = 1; m < 5; m++)
for (n = 1; n < 4; n++)
lcd.command(0b00011100); //команда 4-4-5 подвигаем весь экран вправо
delay(100);
lcd.command(0b00011000); //команда 4-4-5 подвигаем весь экран влево
delay(100);
delay(1500);
for (n = 1; n < 5; n++)
lcd.command(0b00001000); //команда 4-4-4 выключим дисплей
delay(100);
lcd.command(0b00001100); //команда 4-4-4 включим дисплей
delay(100);
delay(1500);
for (n=1;n<3;n++){
lcd.command(0b00101101); //команда 4-4-6 установка яркости 75%
delay(200);
lcd.command(0b00101110); //команда 4-4-6 установка яркости 50%
delay(200);
lcd.command(0b00101111); //команда 4-4-6 установка яркости 25%
delay(200);
delay(200);
delay(200);
lcd.command(0b00101100); //команда 4-4-6 установка яркости 100%
delay(200);
delay(1000);
// lcd.command(0b00000001); //очистка дисплея
// delay(100);
lcd.command(0b00001101); // Мигающий прямоугольник (команда 4-4-4)
for (n = 0; n < 20; n++)
lcd.setCursor(n,0);
delay(200);
lcd.command(0b00001110); // Курсор (команда 4-4-4)
lcd.setCursor(n,1);
delay(200);
lcd.command(0b00001111); // Курсор и мигающий прямоугольник (команда 4-4-4)
lcd.setCursor(n,2);
delay(200);
lcd.command(0b00001100); // Курсор выключен (команда 4-4-4)
delay(200);
