ESP, IoT ESP8266, проблема с компиляцией скетча
Yarosh
22 Ноя 2019
Друзья, привет!
Подскажите что не так, уже все что можно перепробовал, архиваторы менял....
Arduino: 1.8.16 (Windows 10), Плата:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (2M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from C:\Users\Yaroslav\Documents\Arduino\libraries\Gyver_Ambilight_v1.3\Gyver_Ambilight_v1.3.ino:27:0:
C:\Program Files (x86)\Arduino\libraries\FastLED-master/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.005
# pragma message "FastLED version 3.001.005"
In file included from C:\Program Files (x86)\Arduino\libraries\FastLED-master/led_sysdefs.h:27:0,
from C:\Program Files (x86)\Arduino\libraries\FastLED-master/FastLED.h:44,
C:\Program Files (x86)\Arduino\libraries\FastLED-master/platforms/esp/8266/led_sysdefs_esp8266.h:15:17: error: conflicting declaration 'typedef uint8_t boolean'
typedef uint8_t boolean;
In file included from sketch\Gyver_Ambilight_v1.3.ino.cpp:1:0:
C:\Users\Yaroslav\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266/Arduino.h:191:14: error: 'boolean' has a previous declaration as 'typedef bool boolean'
typedef bool boolean;
In file included from C:\Program Files (x86)\Arduino\libraries\FastLED-master/FastLED.h:65:0,
C:\Program Files (x86)\Arduino\libraries\FastLED-master/fastspi.h:110:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
In file included from C:\Program Files (x86)\Arduino\libraries\FastLED-master/FastLED.h:48:0,
C:\Program Files (x86)\Arduino\libraries\FastLED-master/fastpin.h: In instantiation of 'class FastPin<13u>':
C:\Program Files (x86)\Arduino\libraries\FastLED-master/platforms/esp/8266/clockless_esp8266.h:21:49: required from 'class ClocklessController<13, 20, 50, 30, (EOrder)66u, 0, false, 5>'
C:\Program Files (x86)\Arduino\libraries\FastLED-master/chipsets.h:468:7: required from 'class WS2812Controller800Khz<13u, (EOrder)66u>'
C:\Program Files (x86)\Arduino\libraries\FastLED-master/FastLED.h:100:52: required from 'class WS2812<13u, (EOrder)66u>'
C:\Program Files (x86)\Arduino\libraries\FastLED-master/FastLED.h:294:39: required from 'static CLEDController& CFastLED::addLeds(CRGB*, int, int) [with CHIPSET = WS2812; unsigned char DATA_PIN = 13u; EOrder RGB_ORDER = (EOrder)66u]'
C:\Users\Yaroslav\Documents\Arduino\libraries\Gyver_Ambilight_v1.3\Gyver_Ambilight_v1.3.ino:33:54: required from here
C:\Program Files (x86)\Arduino\libraries\FastLED-master/fastpin.h:206:2: error: static assertion failed: Invalid pin specified
static_assert(validpin(), "Invalid pin specified");
exit status 1
Ошибка компиляции для платы NodeMCU 1.0 (ESP-12E Module).
Yarosh
22 Ноя 2019
4,670
1,579
@Yarosh,
проще будет купить плату, и, скорее всего, даже быстрее.
Вам без разницы какой проект?
Тогда WLED или Лампа Гайвера будет хорошим вариантом для первого знакомства.
_Da_ViNCi_
10 Сен 2021
ESP32. Скетч LedPanelWiFi_v1.14
среда разработки Ардуино 1.8.13
до этого было LittleFS.h: No such file or directory
после выполнения инструкции из описания самой библиотеки:
exit status 1
'LittleFS' was not declared in this scope
по нажатию на ESP32 LITTLEFS Date Updload:
LITTLEFS Error: mklittlefs not found!
Хелп, уже так сильно пожелел что взял эту esp32. Все остальные скетчи тоже перемучил, уже тупик
Владислав1234456
28 Апр 2023
Здраствуйте. Помогите пожалуйста с компиляцией. Arduino: 2.1.1 (Windows 11), Плата:"WemosD1 R2 & mini , 160 MHz, Flash, Disabled, All SSL ciphers (most compatible) , 4M (2M SPIFFS), v2 IPV6 Higher Bandwidth, Disabled, None, Only Sketch, 921600"
In file included from c:\Arduino\libraries\FastLED\src/platforms/esp/8266/fastled_esp8266.h:9:0,
from c:\Arduino\libraries\FastLED\src/platforms.h:40,
from c:\Arduino\libraries\FastLED\src/FastLED.h:62,
from C:\Users\92062\OneDrive\Рабочий стол\GyverLamp2-main\firmware\GyverLamp2\palettes.h:1,
from C:\Users\92062\OneDrive\Рабочий стол\GyverLamp2-main\firmware\GyverLamp2\GyverLamp2.ino:97:
c:\Arduino\libraries\FastLED\src/platforms/esp/8266/clockless_esp8266.h:85:18: error: expected ';' at end of member declaration
static uint32_t IRAM_ATTR showRGBInternal(PixelController<RGB_ORDER> pixels) {
c:\Arduino\libraries\FastLED\src/platforms/esp/8266/clockless_esp8266.h:85:77: error: ISO C++ forbids declaration of 'showRGBInternal' with no type [-fpermissive]
In file included from c:\Arduino\libraries\FastLED\src/platforms/esp/8266/fastled_esp8266.h:10:0,
c:\Arduino\libraries\FastLED\src/platforms/esp/8266/clockless_block_esp8266.h:111:18: error: expected ';' at end of member declaration
static uint32_t IRAM_ATTR showRGBInternal(PixelController<RGB_ORDER, LANES, PORT_MASK> &allpixels) {
c:\Arduino\libraries\FastLED\src/platforms/esp/8266/clockless_block_esp8266.h:111:99: error: ISO C++ forbids declaration of 'showRGBInternal' with no type [-fpermissive]
In file included from c:\Arduino\libraries\FastLED\src/FastLED.h:75:0,
c:\Arduino\libraries\FastLED\src/fastspi.h:157:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
exit status 1
Compilation error: exit status 1
Smirniy
14 Май 2023
Здравствуйте. При компиляции скетча gunner47 v.2 всплывает следующее сообщение красного цвета:
ПРЕДУПРЕЖДЕНИЕ: библиотека Timezone должна запускаться на архитектурах (avr) и может быть несовместима с вашей платой на архитектуре (esp8266).
In file included from D:\GGGG\GyverLamp-master\firmware\gunner47_v2.87in1\gunner47_v2.87in1.ino:296:0:
K:\Program Files\Arduino\libraries\FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.003.002
# pragma message "FastLED version 3.003.002"
In file included from K:\Program Files\Arduino\libraries\FastLED/FastLED.h:65:0,
K:\Program Files\Arduino\libraries\FastLED/fastspi.h:130:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
K:\Program Files\Arduino\libraries\FastLED/fastspi.h:131:23: note: #pragma message: Всё идёт хорошо. Ожидайте!
# pragma message "Всё идёт хорошо. Ожидайте!"
Действительно ли всё нормально? Задаю этот вопрос, потому как, мне кажется, прошивка прошла не совсем так, как надо и лампа не заработала.
NikitaGut
3 Ноя 2023
Здравствуйте, вылезает ошибка: 'D2' was not declared in this scope
И указывает на эту строку: #define BTN_PIN D2
Помогите решить
4,670
1,579
@NikitaGut,
либо версия ядра не та, какую автор проекта вас учил выбирать, либо плата не та выбрана.
Реакции: NikitaGut
Сергей Кас
7 Ноя 2023
@MarioPluss2, мне помогло удаление повторяющихся библиотек в C:\Users\Documents\Arduino\libraries. Оставил библиотеки только в папке с программой , что в Program Files
Садриддин
16 Ноя 2023
Ошибка в скече guner47_v2.87in1
Добрый день , нужна помощь , ошибка компиляции выдает вот такую ошибку
784:8: error : #endif without # if
Цифра 784:8: - это строка на которой выявлена ошибка . но в коде такой строки вообще нет ! Помогите что хочет от меня эта прога ????
Загружаю со смартфона приложением Ардуино дроид . Другие прошивки грузятся легко без ошибок к примеру guner47 1.5 , грузится и работает отлично . Прошивка спектроанализатора тоже , все работает . Библиотеки загрузил в ручную путем копирования файлов библиотек в папку либререс , кое какие были заменены .
Помогите что нужно сделать ????
4,670
1,579
@Садриддин,
по-моему, вы собираетесь бороться не со скетчем, не с ошибкой в коде, а с приложением.
@Садриддин,
в вашем приложении прошивку, наверное, как-то можно скомпилировать, если автор приложения исправит баг,
либо если кто-то разберётся из-за чего возникает баг и как его обойти.
Но вряд ли найдётся энтузиаст, готовый этой фигнёй заниматься.
Мороки много, а профита нет.
Можете самостоятельно попробовать найти строчки на русском языке, размещённые после строк, содержащих символы #if
и удалить их.
Они там в паре мест должны найтись.
Flaren
22 Дек 2023
Добрый день, при компиляции скетча для GyverTWink вылазит ошибка, пожалуйста помогите
In file included from c:\Users\Fanof\Documents\Arduino\libraries\FastLED\src/FastLED.h:79,
from C:\Users\Fanof\Downloads\GyverTwink-main\GyverTwink-main\firmware\GyverTwink_v1.2\GyverTwink_v1.2.ino:40:
c:\Users\Fanof\Documents\Arduino\libraries\FastLED\src/fastspi.h:157:23: note: '#pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output'
157 | # pragma message "No hardware SPI pins defined. All SPI access will default to bitbanged output"
C:\Users\Fanof\Downloads\GyverTwink-main\GyverTwink-main\firmware\GyverTwink_v1.2\GyverTwink_v1.2.ino:52:1: error: 'EncButton' is not a template
52 | EncButton<EB_TICK, BTN_PIN> btn;
C:\Users\Fanof\Downloads\GyverTwink-main\GyverTwink-main\firmware\GyverTwink_v1.2\GyverTwink_v1.2.ino:52:11: error: 'EB_TICK' was not declared in this scope; did you mean 'EB_CLICK'?
| EB_CLICK
C:\Users\Fanof\Downloads\GyverTwink-main\GyverTwink-main\firmware\GyverTwink_v1.2\startup.ino: In function 'bool checkButton()':
C:\Users\Fanof\Downloads\GyverTwink-main\GyverTwink-main\firmware\GyverTwink_v1.2\startup.ino:31:13: error: 'class EncButton' has no member named 'state'
31 | if (btn.state()) return true;
exit status 1
Compilation error: 'EncButton' is not a template
4,670
1,579
@Flaren,
библиотеки нужно скопировать из архива с прошивкой, а остальные удалить.
egor_arhipov
23 Дек 2023
При попытке компиляции вылазит такая ошибка, помогите исправить пожалуйста
C:\Users\user\gunner47_v2.87in1\GyverLamp-master\firmware\gunner47_v2.87in1\gunner47_v2.87in1.ino:6:10: fatal error: strings_en.h: No such file or directory
6 | #include <strings_en.h>
compilation terminated.
exit status 1
Compilation error: strings_en.h: No such file or directory
R0mpirp
3 Янв 2023
Всем привет, если есть кто живой в этой теме помогите пожалуйста. Пытаюсь установить прошивку под огненную лампу от грунера и выдает такую ошибку, хотя на версии 1.3 все заливается, вот с 1.4 уже проблемы...
Arduino: 1.8.19 (Windows 10), Плата:"Generic ESP8266 Module, 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), nodemcu, 26 MHz, 40MHz, DOUT (compatible), 1M (64K SPIFFS), 2, nonos-sdk 2.2.1 (legacy), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from W:\Users\F\Desktop\GyverLamp-master\firmware\GyverLamp_v1.4\GyverLamp_v1.4.ino:122:0:
W:\Users\F\Documents\Arduino\libraries\FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.003.002
In file included from W:\Users\F\Documents\Arduino\libraries\FastLED/FastLED.h:65:0,
W:\Users\F\Documents\Arduino\libraries\FastLED/fastspi.h:130:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
W:\Users\F\Desktop\GyverLamp-master\firmware\GyverLamp_v1.4\GyverLamp_v1.4.ino: In function 'void setup()':
GyverLamp_v1.4:405:3: error: 'timeClient' was not declared in this scope
timeClient.begin();
W:\Users\F\Desktop\GyverLamp-master\firmware\GyverLamp_v1.4\time.ino: In function 'void timeTick()':
time:50:21: error: 'timeClient' was not declared in this scope
timeSynched = timeClient.update() || timeSynched; // если время хотя бы один раз было синхронизировано, продолжаем
time:56:33: error: 'localTimeZone' was not declared in this scope
time_t currentLocalTime = localTimeZone.toLocal(timeClient.getEpochTime());
W:\Users\F\Desktop\GyverLamp-master\firmware\GyverLamp_v1.4\time.ino: In function 'void getFormattedTime(char*)':
time:176:47: error: 'currentLocalTime' was not declared in this scope
sprintf_P(buf, PSTR("%02u:%02u:%02u"), hour(currentLocalTime), minute(currentLocalTime), second(currentLocalTime));
exit status 1
4,670
1,579
@R0mpirp,
библиотеки не те, что в архиве с прошивкой лежат.
И вам лучше версию прошивки новее найти тут на форуме, чтобы других проблем решать не пришлось.
@R0mpirp,
в шапке версию по-новее.
