ARDUINO Как решить ошибку компиляции и объединить две библиотеки NecDecoder.h EasyHID.h
Murat8877
18 Мар 2022
#include <NecDecoder.h>
#include <EasyHID.h>
NecDecoder ir;
  attachInterrupt(1, irIsr, FALLING);
  HID.begin();
void irIsr() {
  ir.tick();
    HID.tick();
Arduino: 1.8.19 (Windows 10), Плата:"Arduino Nano, ATmega328P (Old Bootloader)"
C:\Users\User\Documents\Arduino\libraries\EasyHID-main\HIDPrivate.c: In function 'usbFunctionSetup':
C:\Users\User\Documents\Arduino\libraries\EasyHID-main\HIDPrivate.c:139:19: warning: assignment makes integer from pointer without a cast [-Wint-conversion]
usbMsgPtr = &idle_rate; // send data starting from this byte
C:\Users\User\Documents\Arduino\libraries\EasyHID-main\HIDPrivate.c:145:19: warning: assignment makes integer from pointer without a cast [-Wint-conversion]
usbMsgPtr = &protocol_version; // send data starting from this byte
C:\Users\User\Documents\Arduino\libraries\EasyHID-main\HIDPrivate.c:151:19: warning: assignment makes integer from pointer without a cast [-Wint-conversion]
usbMsgPtr = (uint8_t*)&report_buffer; // send the report data
WInterrupts.c.o (symbol from plugin): In function `attachInterrupt':
(.text+0x0): multiple definition of `__vector_1'
libraries\EasyHID-main\usbdrvasm_includer.S.o:C:\Users\Murat\Documents\Arduino\libraries\EasyHID-main\usbdrv/usbdrvasm16.inc:35: first defined here
C:\Users\User\AppData\Local\Temp\ccBy1LGa.ltrans0.ltrans.o: In function `__vector_1':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/WInterrupts.c:372: multiple definition of `__vector_1'
collect2.exe: error: ld returned 1 exit status
exit status 1
p.s я новичок
1,010
а если так:
attachInterrupt(2, irIsr, FALLING);
есть ошибка?
Murat8877
18 Мар 2022
@bort707,
NecDecoder ir;
  HID.begin();
void irIsr() {
  ir.tick();
    HID.tick();
C:\Users\user\AppData\Local\Temp\ccwTTH4H.ltrans0.ltrans.o: In function `__vector_1':
libraries\EasyHID-main\usbdrvasm_includer.S.o:C:\Users\user\Documents\Arduino\libraries\EasyHID-main\usbdrv/usbdrvasm16.inc:35: first defined here
exit status 1
Sergo_ST
15 Мар 2020
1,334
969
Крайне странное поведение attachInterrupt, такое чувство как будто она определяет сразу оба вектора прерывания...
Придется напрямую:
NecDecoder ir;
  HID.begin();
  EICRA &= ~(0x01 << ISC10);
  EICRA |= (0x01 << ISC11); //настраиваем внешнее прерывание по спаду импульса на INT1
  EIMSK |= (0x01 << INT1); //разрешаем внешнее прерывание INT1
ISR(INT1_vect) { //внешнее прерывание на пине INT1
  ir.tick();
void irIsr() {
  ir.tick();
  HID.tick();
Реакции: Murat8877
1,061
@Murat8877, номера векторов и номера пинов не совпадают. Используйте digitalPinToInterrupt(pin)
