U4GM Guide to Currency Management in Arknights Endfield
Andrew736
6 Май 2026
Plenty of players burn out in Arknights: Endfield because they treat every banner like an emergency. It isn't. If you want steady progress, you've got to think a few weeks ahead instead of chasing whatever just showed up. Some people even choose to buy Arknights endfield account so they can skip the slow early build, but if you're growing your own roster, discipline matters more than luck. The easiest rule to remember is this: use limited banner permits first, every single time. Letting those expire while your permanent Chartered Headhunting tickets sit untouched is one of those mistakes that feels small at first, then really stings later.
Pull plans that actually make sense
There's no point pretending gacha is generous if you can't reach the safety line. The 120-pull guarantee only helps when you've saved enough to get there, so random pulling usually does more harm than good. If you're short, just hold. A lot of players ignore the slow-and-safe route, but it works. Take the free 10-pull opportunities from logins, grab what you can from the AIC Quota shop, and build pity without draining Oroberyl. That's the kind of patience that keeps an account healthy. The same goes for Origeometry. Don't dump it straight into pulls unless you're absolutely desperate. In most cases, the Protocol Pass gives you far better value over time, and you'll feel that difference a month later.
Daily farming without wasting stamina
The grind gets boring, sure, but daily resource habits are where strong accounts are built. Rare materials are the big one. Even if you don't need them today, pick them up when they're available. Their respawn timers can be annoying, and somehow the item you skipped is always the one you need during a promotion rush. Stamina should go toward stages that still matter next week, not easy filler nodes with poor returns. A solid target for your main squad is level 60. That's where things start opening up, especially high-tier gold gear. Pushing everyone to 80 or 90 too early looks nice on paper, but it eats resources fast and slows your overall progress more than people expect.
Base upgrades and factory flow
Your base is where passive income either works for you or quietly falls apart. Stock Bills shouldn't sit around for long. Put them back into infrastructure, especially Depot Stations and factory upgrades, because those improvements keep paying out later. You'll also want to check production chains properly. If a machine needs two materials and you're feeding only one, you're not being efficient, you're just leaving output on the table. Outposts need attention too. If they cap while you're away, that's lost income, plain and simple. And yes, checking friend listings for elastic goods can feel a bit tedious, but buying them before reset is one of the better ways to grow your Stock Bills without doing anything flashy.
Playing the long game
What usually separates comfortable accounts from struggling ones isn't insane luck, it's consistency. Save when it's boring, farm before you're desperate, and build systems that keep earning while you do other things. As a professional platform for game currency and item services, U4GM is known for being convenient and reliable, and if you want a smoother start or a stronger roster, u4gm Arknights endfield account Buy can be a practical option for improving your overall experience in the game.
