ESP, IoT ESP8266, проблема с компиляцией скетча
Помогите запустить скетч
BLUETOOTH МАТРИЦА НА АДРЕСНЫХ СВЕТОДИОДАХ
Имею esp8266.
Библиотеки поставил, порт и плату выбрал по инструкции. При компиляции получаю вот это:
Arduino: 1.8.2 (Windows 10), Плата:"WeMos D1 R1, 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
In file included from C:\Users\Admin_scamt\Downloads\GyverMatrixBT-master\firmware\GyverMatrixOS_v1.11\GyverMatrixOS_v1.11.ino:137:0:
C:\Users\Admin_scamt\Documents\Arduino\libraries\FastLED-stm32patch/FastLED.h:17:21: note: #pragma message: FastLED version 3.002.000
# pragma message "FastLED version 3.002.000"
In file included from C:\Users\Admin_scamt\Documents\Arduino\libraries\FastLED-stm32patch/led_sysdefs.h:24:0,
from C:\Users\Admin_scamt\Documents\Arduino\libraries\FastLED-stm32patch/FastLED.h:44,
C:\Users\Admin_scamt\Documents\Arduino\libraries\FastLED-stm32patch/platforms/esp/8266/led_sysdefs_esp8266.h:15:17: error: conflicting declaration 'typedef uint8_t boolean'
typedef uint8_t boolean;
In file included from sketch\GyverMatrixOS_v1.11.ino.cpp:1:0:
C:\Users\Admin_scamt\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.1\cores\esp8266/Arduino.h:191:14: error: 'boolean' has a previous declaration as 'typedef bool boolean'
typedef bool boolean;
In file included from C:\Users\Admin_scamt\Documents\Arduino\libraries\FastLED-stm32patch/FastLED.h:68:0,
C:\Users\Admin_scamt\Documents\Arduino\libraries\FastLED-stm32patch/fastspi.h:110:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
exit status 1
Ошибка компиляции для платы WeMos D1 R1.
29 Апр 2020
Подскажите пожалуйста, не компилится скретч:
In file included from F:\!Arduino\GyverLamp-master\GyverLamp-master\firmware\GyverLamp_v1.5.5\GyverLamp_v1.5.5.ino:97:0:
C:\Program Files (x86)\Arduino\libraries\FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.002.009
In file included from C:\Program Files (x86)\Arduino\libraries\FastLED/FastLED.h:65:0,
C:\Program Files (x86)\Arduino\libraries\FastLED/fastspi.h:115:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
Библиотеки менял, старые удалял, прошивка платы 2.52,
причем нет компиляции на обоих платах,
и аналогичная ошибка выскакивает в светодиодном рюкзаке
  • Аррр! -2
Реакции: kostyamat
632
@Владимир дрдр, вся эта тема ответами на ваш вопрос утыкана, на каждой, мать ее странице. Читать не пробовали, хотя бы пару страниц ДО того как писать?
pifupafu
15 Май 2020
Доброго вечера проблема с компиляцией
C:\Users\povar\Documents\Arduino\libraries\WiFiManager/WiFiManager.h:25:24: note: in expansion of macro 'PROGMEM'
const char HTTP_HEAD[] PROGMEM = "<!DOCTYPE html><html lang=\"en\"><head><meta charset=\"UTF-8\" name=\"viewport\" content=\"width=device-width, initial-scale=1, user-scalable=no\"/><title>{v}</title>";
In file included from C:\Users\povar\Desktop\GyverLamp-master\firmware\GyverLamp_v1.5.5\GyverLamp_v1.5.5.ino:100:0:
C:\Users\povar\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266WebServer\src/ESP8266WebServer.h:34:39: error: previous declaration of 'HTTPMethod HTTP_HEAD'
enum HTTPMethod { HTTP_ANY, HTTP_GET, HTTP_HEAD, HTTP_POST, HTTP_PUT, HTTP_PATCH, HTTP_DELETE, HTTP_OPTIONS };
Несколько библиотек найдено для "WiFiManager.h"
Используется: C:\Users\povar\Documents\Arduino\libraries\WiFiManager
Не используется: C:\Program Files (x86)\Arduino\libraries\WiFiManager
Несколько библиотек найдено для "NTPClient.h"
Используется: C:\Program Files (x86)\Arduino\libraries\NTPClient
Не используется: C:\Program Files (x86)\Arduino\libraries\NTPClient-master
Не используется: C:\Users\povar\Documents\Arduino\libraries\NTPClient-master
Несколько библиотек найдено для "GyverButton.h"
Используется: C:\Users\povar\Documents\Arduino\libraries\GyverButton
Не используется: C:\Program Files (x86)\Arduino\libraries\GyverButton
Несколько библиотек найдено для "FastLED.h"
Используется: C:\Users\povar\Documents\Arduino\libraries\FastLED-3.2.9
Не используется: C:\Program Files (x86)\Arduino\libraries\FastLED-3.2.9
Используем библиотеку FastLED-3.2.9 версии 3.2.9 из папки: C:\Users\povar\Documents\Arduino\libraries\FastLED-3.2.9
Используем библиотеку ESP8266WiFi версии 1.0 из папки: C:\Users\povar\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266WiFi
Используем библиотеку DNSServer версии 1.1.1 из папки: C:\Users\povar\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\DNSServer
Используем библиотеку ESP8266WebServer версии 1.0 из папки: C:\Users\povar\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266WebServer
Используем библиотеку WiFiManager версии 0.14 из папки: C:\Users\povar\Documents\Arduino\libraries\WiFiManager
Используем библиотеку EEPROM версии 1.0 из папки: C:\Users\povar\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\EEPROM
Используем библиотеку NTPClient версии 3.2.0 из папки: C:\Program Files (x86)\Arduino\libraries\NTPClient
Используем библиотеку GyverButton в папке: C:\Users\povar\Documents\Arduino\libraries\GyverButton (legacy)
exit status 1
Ошибка компиляции для платы NodeMCU 1.0 (ESP-12E Module).
Александр Симонов
2 Авг 2018
737
208
exit status 1
Версия ядра esp8266 не та. Перечитай инструкцию на странице проекта
tebe_yasn0
Помогите с ошибкой
Arduino: 1.8.2 (Windows 10), Плата:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (1M SPIFFS), v2 Higher Bandwidth (no features), Disabled, None, Only Sketch, 115200"
Изменены опции сборки, пересобираем все
ПРЕДУПРЕЖДЕНИЕ: библиотека Timezone должна запускаться на архитектурах (avr) и может быть несовместима с вашей платой на архитектуре (esp8266).
In file included from C:\Users\yasn0.DESKTOP-S9K21BH\Desktop\gunner47_v1.5\GyverLamp-master\firmware\gunner47_v1.5\gunner47_v1.5.ino:144:0:
C:\Users\yasn0.DESKTOP-S9K21BH\Documents\Arduino\libraries\FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.002.009
In file included from C:\Users\yasn0.DESKTOP-S9K21BH\Documents\Arduino\libraries\FastLED/FastLED.h:65:0,
C:\Users\yasn0.DESKTOP-S9K21BH\Documents\Arduino\libraries\FastLED/fastspi.h:115:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
gunner47_v1.5:202: error: 'showWarning' was not declared in this scope
OtaManager otaManager(&showWarning);
C:\Users\yasn0.DESKTOP-S9K21BH\Desktop\gunner47_v1.5\GyverLamp-master\firmware\gunner47_v1.5\gunner47_v1.5.ino: In function 'void setup()':
gunner47_v1.5:381: error: 'showWarning' was not declared in this scope
showWarning(CRGB::Yellow, 1000U, 500U); // мигание жёлтым цветом 0,5 секунды (1 раз) - нужно ввести параметры WiFi сети для подключения
gunner47_v1.5:417: error: 'showWarning' was not declared in this scope
showWarning(CRGB::Red, 1000U, 500U); // мигание красным цветом 0,5 секунды (1 раз) - ожидание ввода SSID'а и пароля WiFi сети прекращено, перезагрузка
C:\Users\yasn0.DESKTOP-S9K21BH\Desktop\gunner47_v1.5\GyverLamp-master\firmware\gunner47_v1.5\button.ino: In function 'void buttonTick()':
button:143: error: 'showWarning' was not declared in this scope
showWarning(CRGB::Red, 3000U, 500U); // мигание красным цветом 3 секунды - смена рабочего режима лампы, перезагрузка
exit status 1
Стер все библиотеки, поставил через менеджер, все равно ошибка
Александр Симонов
2 Авг 2018
737
208
Помогите с ошибкой
Для начала обнови Arduino IDE
дрим93
16 Ноя 2018
35
In file included from C:\Users\1\Downloads\gunner47_v1.5.69in1\GyverLamp-master\firmware\gunner47_v1.5.69in1\gunner47_v1.5.69in1.ino:200:0:
C:\Program Files (x86)\arduino-1.8.8\libraries\FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.003.002
# pragma message "FastLED version 3.003.002"
In file included from C:\Program Files (x86)\arduino-1.8.8\libraries\FastLED/FastLED.h:65:0,
C:\Program Files (x86)\arduino-1.8.8\libraries\FastLED/fastspi.h:130:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
C:\Users\1\Downloads\gunner47_v1.5.69in1\GyverLamp-master\firmware\gunner47_v1.5.69in1\button.ino: In function 'void buttonTick()':
button:159:19: error: 'class GButton' has no member named 'getHoldClicks'
switch (touch.getHoldClicks())
Используется: C:\Program Files (x86)\arduino-1.8.8\libraries\FastLED
Не используется: C:\Program Files (x86)\arduino-1.8.8\libraries\FastLED-3.2.9
Несколько библиотек найдено для "EEPROM.h"
Используется: C:\Users\1\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\EEPROM
Не используется: C:\Program Files (x86)\arduino-1.8.8\libraries\E2PROM
Используется: C:\Program Files (x86)\arduino-1.8.8\libraries\NTPClient
Не используется: C:\Users\1\Documents\Arduino\libraries\esp8266-weather-station-master
Не используется: C:\Program Files (x86)\arduino-1.8.8\libraries\NTPClient-master
Несколько библиотек найдено для "ESP8266WebServer.h"
Используется: C:\Users\1\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WebServer
Не используется: C:\Program Files (x86)\arduino-1.8.8\libraries\ESPWebServer-master
exit status 1
Неверная библиотека найдена в C:\Program Files (x86)\arduino-1.8.8\libraries\DFPlayerMini_Fast-master: нет заголовочных файлов (.h), найденных в C:\Program Files (x86)\arduino-1.8.8\libraries\DFPlayerMini_Fast-master
Неверная библиотека найдена в C:\Program Files (x86)\arduino-1.8.8\libraries\FastLED-master: нет заголовочных файлов (.h), найденных в C:\Program Files (x86)\arduino-1.8.8\libraries\FastLED-master
как победить???
Vasylij
8 Фев 2020
добрый день
помогите пожалуйста в чём состоит ошибка при прошивке 1.12 на вемос д1 р1:
In file included from E:\ARDUINO PROJEKT\MATRIZA_OKNO\GyverMatrixBT-master\firmware\GyverMatrixOS_v1.12\GyverMatrixOS_v1.12.ino:138:0:
C:\Program Files (x86)\Arduino\libraries\FastLED/FastLED.h:17:21: note: #pragma message: FastLED version 3.002.000
In file included from C:\Program Files (x86)\Arduino\libraries\FastLED/led_sysdefs.h:27:0,
from C:\Program Files (x86)\Arduino\libraries\FastLED/FastLED.h:44,
C:\Program Files (x86)\Arduino\libraries\FastLED/platforms/esp/8266/led_sysdefs_esp8266.h:15:17: error: conflicting declaration 'typedef uint8_t boolean'
In file included from sketch\GyverMatrixOS_v1.12.ino.cpp:1:0:
C:\Users\����\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266/Arduino.h:191:14: error: 'boolean' has a previous declaration as 'typedef bool boolean'
In file included from C:\Program Files (x86)\Arduino\libraries\FastLED/FastLED.h:68:0,
C:\Program Files (x86)\Arduino\libraries\FastLED/fastspi.h:110:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
Используется: C:\Program Files (x86)\Arduino\libraries\FastLED
Не используется: C:\Program Files (x86)\Arduino\libraries\FastLED-master
Не используется: C:\Users\вася\Documents\Arduino\libraries\FastLED-master
exit status 1
Caxap
1 Июн 2020
Здравствуйте!
Хотел сделать лампу, но при прошывке NodeMCU возникает такая ошибка.Подскажите пожалуйста, в чем может быть проблема?
Arduino: 1.8.2 (Windows 10), Плата:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from C:\Users\Рузаль\Desktop\GyverLamp-master (1) (3)\GyverLamp-master\firmware\GyverLamp_v1.5.5\GyverLamp_v1.5.5.ino:97:0:
F:\Prog\arduino\libraries\FastLED-3.2.9/FastLED.h:14:21: note: #pragma message: FastLED version 3.002.009
In file included from F:\Prog\arduino\libraries\FastLED-3.2.9/FastLED.h:65:0,
F:\Prog\arduino\libraries\FastLED-3.2.9/fastspi.h:115:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
Archiving built core (caching) in: C:\Users\BE47~1\AppData\Local\Temp\arduino_cache_508494\core\core_esp8266_esp8266_nodemcuv2_xtal_80,vt_flash,exception_disabled,eesz_4M,ip_lm2f,dbg_Disabled,lvl_None____,wipe_none,baud_115200_6d2fd5cbef65f0c0a285a16f6c765504.a
Скетч использует 328392 байт (31%) памяти устройства. Всего доступно 1044464 байт.
Глобальные переменные используют 44448 байт (54%) динамической памяти, оставляя 37472 байт для локальных переменных. Максимум: 81920 байт.
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
4,557
1,546
@Vasylij, для начала удалите содержимое папки
и положите только то, что лежит в архиве с прошивкой в аналогичной папке.
4,557
1,546
@Caxap, прошивка у вас скомпилировалась,
а вот загрузиться в контроллер не может.
Это там просят спрашивать: https://community.alexgyver.ru/threads/wifi-lampa-budilnik-obsuzhdenie-proekta.1411/page-201
В интернетах пишут всякое типа:
"решение проблемы - закоротить ногу D3 (она же GPIO0) на землю."
А вообще начали бы вы с того, что обновили версию Arduino IDE.
Откуда вы берёте старые версии летом 20го года?!
exby
24 Мар 2020
подскажите, в чем проблема? прошиваю прошивку gunner47_v1.5 и не компилится, версия 1.4 компилится и версия от алексагувера тоже компилится и прошивается
In file included from C:\Users\User\Desktop\GyverLamp-master\firmware\gunner47_v1.5\gunner47_v1.5.ino:144:0:
C:\Program Files (x86)\Arduino\libraries\FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.003.002
C:\Program Files (x86)\Arduino\libraries\FastLED/fastspi.h:130:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
C:\Users\User\Desktop\GyverLamp-master\firmware\gunner47_v1.5\gunner47_v1.5.ino: In function 'void setup()':
gunner47_v1.5:343:50: error: 'GlobalBrightness' was not declared in this scope
&(FavoritesManager::SaveFavoritesToEeprom), &GlobalBrightness);
gunner47_v1.5:398:11: error: 'isWifiOffMode' was not declared in this scope
isWifiOffMode = true;
gunner47_v1.5:407:12: error: 'needconfigure' was not declared in this scope
if ( needconfigure) { // Проверка. Требуется ли дополнительная конфигурация?
gunner47_v1.5:417:35: error: 'host_name' was not declared in this scope
wifiManager.autoConnect(host_name.c_str(), AP_PASS); // пытаемся подключиться к сохранённой ранее WiFi сети; в случае ошибки, будет развёрнута WiFi точка доступа с указанными AP_NAME и паролем на время ESP_CONN_TIMEOUT секунд; http://AP_STATIC_IP:ESP_HTTP_PORT (обычно http://192.168.0.1:80) - страница для ввода SSID и пароля от WiFi сети роутера
gunner47_v1.5:562:9: error: 'isWifiOffMode' was not declared in this scope
gunner47_v1.5:601:5: error: 'mqttClient' was not declared in this scope
mqttClient = new AsyncMqttClient();
gunner47_v1.5:601:22: error: expected type-specifier before 'AsyncMqttClient'
gunner47_v1.5:601:22: error: expected ';' before 'AsyncMqttClient'
gunner47_v1.5:602:5: error: 'MqttManager' has not been declared
MqttManager::setupMqtt(mqttClient, inputBuffer, &sendCurrent); // создание экземпляров объектов для работы с MQTT, их инициализация и подключение к MQTT брокеру
exit status 1
Nion_eto
26 Сен 2020
Доброго дня уважаемые. С ардуино знакомлюсь впервые. Есть nodeMCU Lua V3 совместимый на ESP8266 (CH340G), хочу через блинк выводить инофрмацию с двух далласов DS18B20 выводить информацию на смарт, нашел у одного парня скетч, все вроде поправил под свою сеть и код который выслал блинк, но не компилируется скетч. Прошу помочь не пойму, на что он ругается.
In file included from C:\Users\IGOR\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:17:0,
from C:\Users\IGOR\Documents\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14,
from C:\Users\IGOR\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp8266.h:24,
from D:\!Avtomatika\Arduino\Файлы скетч blink_ds18b20\blink_ds18b20.ino\blink_ds18b20.ino.ino:3:
C:\Users\IGOR\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:36:21: error: redefinition of 'class BlynkTimer'
#define SimpleTimer BlynkTimer
C:\Users\IGOR\Documents\Arduino\libraries\SimpleTimer/SimpleTimer.h:10:7: note: in expansion of macro 'SimpleTimer'
class SimpleTimer {
C:\Users\IGOR\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:36:21: error: previous definition of 'class BlynkTimer'
C:\Users\IGOR\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:41:7: note: in expansion of macro 'SimpleTimer'
class SimpleTimer {
exit status 1
Заранее благодарю.
Александр Симонов
2 Авг 2018
737
208
class SimpleTimer {
class SimpleTimer {
exit status 1
Заранее благодарю.
Blynk пытается переопределить класс SimpleTimer, что конфликтует с библиотекой SimpleTimer. Почему, нельзя сказать без скетча. Спросите у автора.
Реакции: Nion_eto
Nion_eto
26 Сен 2020
Я спросил, он молчит =( поэтому к гуру обращаюсь
Ткните пожалуйста носом куда копать, я только начал разбираться в этом, до профи еще далеко =(
Заранее, огромное спасибо
/* ESP & Blynk */
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#define BLYNK_PRINT Serial
/* Blynk credentials */
char auth[] = "Код аутентефикации с приложения blynk который прийдет вам на е-мейл";
/* WiFi credentials */
char ssid[] = "имя сети вай-фай";
char pass[] = "пароль от вай-фая";
/* TIMER */
#include <SimpleTimer.h>
SimpleTimer timer;
/* DS18B20 Temperature Sensor */
#include <OneWire.h>
#include<DallasTemperature.h>
#define ONE_WIRE_BUS 2 // DS18B20 подключаем на D4 на плате
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature DS18B20(&oneWire);
int temp_0;
int temp_1;
void setup()
Blynk.begin(auth, ssid, pass);
DS18B20.begin();
timer.setInterval(1000L, getSendData);
Serial.println(" ");
Serial.println("Testing Dual Sensor data");
void loop()
timer.run(); // Initiates SimpleTimer
Blynk.run();
* Send Sensor data to Blynk
void getSendData()
DS18B20.requestTemperatures();
temp_0 = DS18B20.getTempCByIndex(0); // Sensor 0 показания для датчика 1 в цельсиях
temp_1 = DS18B20.getTempCByIndex(1); // Sensor 0 показания для датчика 2 в цельсиях
Serial.print("Temp_0: ");
Serial.print(temp_0);
Serial.print(" oC . Temp_1: ");
Serial.print(temp_1);
Serial.println(" oC");
Blynk.virtualWrite(10, temp_0); //выврд данных на виртуальный пин V10
Blynk.virtualWrite(11, temp_1); //вывод данных навиртуальный пин V11
Александр Симонов
2 Авг 2018
737
208
Попробуй закоментировать #include <SimpleTimer.h>
Реакции: Nion_eto
Nion_eto
26 Сен 2020
Спасибо, заработало, кривенько, но заработало, огромное спасибо.
Буду искать как вывеси температуру с десятыми градусов
А нет спасибо, нашел
вместо
int temp_0;
int temp_1;
ставлю
float temp_0;
float temp_1;
kindFox
14 Май 2020
привет. проблема компиляции "Ошибка компиляции для платы NodeMCU 1.0 (ESP-12E Module)"
IDE 1.8.13 , менеджер платы 2.7.4
прошиваю скетч лампы 1.5.5 (все библиотеки и файлы скетча из архива)
пишет это:
Arduino: 1.8.13 (Windows 10), Плата:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Higher Bandwidth, Disabled, None, Only Sketch, 115200"
In file included from C:\firmware\GyverLamp_v1.5.5\GyverLamp_v1.5.5.ino:97:0:
C:\Program Files (x86)\Arduino\libraries\FastLED-3.2.9/FastLED.h:14:21: note: #pragma message: FastLED version 3.002.009
In file included from C:\Program Files (x86)\Arduino\libraries\FastLED-3.2.9/FastLED.h:65:0,
C:\Program Files (x86)\Arduino\libraries\FastLED-3.2.9/fastspi.h:115:23: note: #pragma message: No hardware SPI pins defined.  All SPI access will default to bitbanged output
In file included from C:\Users\madam\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include/sys/stdio.h:6:0,
                 from C:\Users\madam\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include/stdio.h:63,
                 from C:\Users\madam\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266/Arduino.h:32,
                 from sketch\GyverLamp_v1.5.5.ino.cpp:1:
C:\Users\madam\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include/sys/pgmspace.h:25:130: error: 'const char HTTP_HEAD []' redeclared as different kind of symbol
   #define PROGMEM [B]attribute[/B]((section( "\".irom.text." [B]FILE[/B] "." [B]STRINGIZE(__LINE[/B]) "."  [B]STRINGIZE(__COUNTER[/B]) "\"")))
C:\Program Files (x86)\Arduino\libraries\WiFiManager/WiFiManager.h:25:24: note: in expansion of macro 'PROGMEM'
In file included from C:\firmware\GyverLamp_v1.5.5\GyverLamp_v1.5.5.ino:100:0:
C:\Users\madam\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WebServer\src/ESP8266WebServer.h:34:39: error: previous declaration of 'HTTPMethod HTTP_HEAD'
exit status 1
George
25 Дек 2019
372
58
А Алекс на своём сайте что говорит?
"ставим ядро для esp версии 2.5.2 "
Как минимум нужно делать для начала то, что требует сам автор...
Реакции: stepko
Delfin888
30 Сен 2020
Arduino: 1.9.0-beta (Windows 10), Плата:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (1M SPIFFS), v2 Higher Bandwidth (no features), Disabled, None, Only Sketch, 115200"
C:\Users\Garazh\Documents\arduino-PR-beta1.9-BUILD-119\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\Garazh\Documents\arduino-PR-beta1.9-BUILD-119\hardware -hardware C:\Users\Garazh\AppData\Local\Arduino15\packages -tools C:\Users\Garazh\Documents\arduino-PR-beta1.9-BUILD-119\tools-builder -tools C:\Users\Garazh\Documents\arduino-PR-beta1.9-BUILD-119\hardware\tools\avr -tools C:\Users\Garazh\AppData\Local\Arduino15\packages -libraries C:\Users\Garazh\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,ssl=all,eesz=4M1M,ip=hb2n,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10900 -build-path C:\Users\Garazh\AppData\Local\Temp\arduino_build_551007 -warnings=all -build-cache C:\Users\Garazh\AppData\Local\Temp\arduino_cache_897170 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.python.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\python\3.7.2-post1 -prefs=runtime.tools.python-3.7.2-post1.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\python\3.7.2-post1 -verbose -experimental C:\Users\Garazh\Documents\Downloads\gunner47_v1.5.82in1\GyverLamp-master\firmware\gunner47_v1.5.82in1\gunner47_v1.5.82in1.ino
C:\Users\Garazh\Documents\arduino-PR-beta1.9-BUILD-119\arduino-builder -compile -logger=machine -hardware C:\Users\Garazh\Documents\arduino-PR-beta1.9-BUILD-119\hardware -hardware C:\Users\Garazh\AppData\Local\Arduino15\packages -tools C:\Users\Garazh\Documents\arduino-PR-beta1.9-BUILD-119\tools-builder -tools C:\Users\Garazh\Documents\arduino-PR-beta1.9-BUILD-119\hardware\tools\avr -tools C:\Users\Garazh\AppData\Local\Arduino15\packages -libraries C:\Users\Garazh\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,ssl=all,eesz=4M1M,ip=hb2n,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10900 -build-path C:\Users\Garazh\AppData\Local\Temp\arduino_build_551007 -warnings=all -build-cache C:\Users\Garazh\AppData\Local\Temp\arduino_cache_897170 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.python.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\python\3.7.2-post1 -prefs=runtime.tools.python-3.7.2-post1.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\python\3.7.2-post1 -verbose -experimental C:\Users\Garazh\Documents\Downloads\gunner47_v1.5.82in1\GyverLamp-master\firmware\gunner47_v1.5.82in1\gunner47_v1.5.82in1.ino
Using board 'nodemcuv2' from platform in folder: C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2
Using core 'esp8266' from platform in folder: C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2
Detecting libraries used...
"C:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Temp\\arduino_build_551007/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=1460 -DLWIP_FEATURES=0 -DLWIP_IPV6=0 -DARDUINO=10900 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "C:\\Users\\Garazh\\AppData\\Local\\Temp\\arduino_build_551007\\sketch\\gunner47_v1.5.82in1.ino.cpp" -o nul
Alternatives for ESP8266WebServer.h: [[email protected]]
ResolveLibrary(ESP8266WebServer.h)
-> candidates: [[email protected]]
"C:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Temp\\arduino_build_551007/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=1460 -DLWIP_FEATURES=0 -DLWIP_IPV6=0 -DARDUINO=10900 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\ESP8266WebServer\\src" "C:\\Users\\Garazh\\AppData\\Local\\Temp\\arduino_build_551007\\sketch\\gunner47_v1.5.82in1.ino.cpp" -o nul
Alternatives for ESP8266WiFi.h: [[email protected]]
ResolveLibrary(ESP8266WiFi.h)
"C:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Temp\\arduino_build_551007/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=1460 -DLWIP_FEATURES=0 -DLWIP_IPV6=0 -DARDUINO=10900 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\ESP8266WebServer\\src" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\Garazh\\AppData\\Local\\Temp\\arduino_build_551007\\sketch\\gunner47_v1.5.82in1.ino.cpp" -o nul
Alternatives for platforms/esp/8266/led_sysdefs_esp8266.h: []
ResolveLibrary(platforms/esp/8266/led_sysdefs_esp8266.h)
In file included from C:\Users\Garazh\AppData\Local\Temp\arduino_build_551007\sketch\FastLED.h:41:0,
-> candidates: []
from C:\Users\Garazh\Documents\Downloads\gunner47_v1.5.82in1\GyverLamp-master\firmware\gunner47_v1.5.82in1\gunner47_v1.5.82in1.ino:218:
led_sysdefs.h:29:52: fatal error: platforms/esp/8266/led_sysdefs_esp8266.h: No such file or directory
#include "platforms/esp/8266/led_sysdefs_esp8266.h"
compilation terminated.
Используем библиотеку ESP8266WebServer версии 1.0 из папки: C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WebServer
Используем библиотеку ESP8266WiFi версии 1.0 из папки: C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi
exit status 1
Что ей не Хватает, не понимаю. Помогите разобраться ??
