Плавное включение адресной светодиодной ленты
DjafarT800
15 Дек 2019
19
Чтож вы, написали функцию ledss() . а не используете?
вот так вроде покороче будет, 100 строчек вместо 140 :)
#include "FastLED.h"
#define PIN 3
#define NUMPIXELS 36
CRGB strip[NUMPIXELS];
const int buttonPin = 4;
const int buttonPin2 = 5;
int buttonState = 0;
int buttonState2 = 0;
int k = 0;
void setup()
FastLED.addLeds<WS2812, PIN, GRB>(strip, NUMPIXELS);
pinMode(buttonPin, INPUT);
pinMode(buttonPin2, INPUT);
ledss();
void ledss(){
//for (int i = 0; i < NUMPIXELS; i++)
    FastLED.setBrightness(k);
    strip[0] = CRGB::White; // Цвет по умолчанию.
    strip[1] = CRGB::White;
    strip[2] = CRGB::Red;
    strip[3] = CRGB::White;
    strip[4] = CRGB::White;
    strip[5] = CRGB::Blue;
    strip[6] = CRGB::White;
    strip[7] = CRGB::Blue;
    strip[8] = CRGB::White;
    strip[9] = CRGB::Blue;
    strip[10] = CRGB::White;
    strip[11] = CRGB::White;
    strip[12] = CRGB::White;
    strip[13] = CRGB::White;
    strip[14] = CRGB::White;
    strip[15] = CRGB::Red;
    strip[16] = CRGB::White;
    strip[17] = CRGB::Blue;
    strip[18] = CRGB::White;
    strip[19] = CRGB::White;
    strip[20] = CRGB::White;
    strip[21] = CRGB::White;
    strip[22] = CRGB::Blue;
    strip[23] = CRGB::White;
    strip[24] = CRGB::White;
    strip[25] = CRGB::Red;
    strip[26] = CRGB::White;
    strip[27] = CRGB::White;
    strip[28] = CRGB::Blue;
    strip[29] = CRGB::White;
    strip[30] = CRGB::White;
    strip[31] = CRGB::Red;
    strip[32] = CRGB::White;
    strip[33] = CRGB::White;
    strip[34] = CRGB::Blue;
    strip[35] = CRGB::White;
   FastLED.show();
   if(k == 0)   //и если свет не был включен
       for(k=0; k<=255; k++)  //то плавно включаем свет
       FastLED.show();
       delay(1000);   //каждые 10мс увелияение на 1
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  buttonState2 = digitalRead(buttonPin2);
  // check if the pushbutton is pressed. If it is, the buttonState is HIGH:
  if (buttonState == HIGH){
    int f = random(0, 255);
    // turn LED on:
    //strip[i] = CHSV(random8(),255,255);
    strip[i] = CHSV(f,255,255);
  // Передаем цвета ленте.
  FastLED.show();
  delay(1000);
  if (buttonState2 == HIGH)
    ledss();
откомпилировать сейчас нечем. так что проверяйте на опечатки
Проверил, при нажатии на 2ю кнопку для выбора цвета по умолчанию свет выключается и больше ни одна кнопка не реагирует. Починил добавлением int k = 0; в тело void ledss()
Я так понял что ардуина только при включении определяла что К равна 0, но при нажатии на кнопку и повторении цикла ардуина уже не понимает 0 или нет. Есть ли у адресной ленты обратная связь, чтоб понимать какой цвет и яркость на данный момент? Например для вывода на экран
b707_2
22 Июл 2020
178
51
что-то я вас не понимаю, можете код показать?
При нажатии кнопки 2 в моем коде свет должен сменится на дефолтный. а яркость не меняется, сколько была до того - столько и остается, параметр k при этом ни на что не влияет
нет, единственный вариант - запоминать в программе, что выводите на ленту
1,332
Не совсем так. У железки обратной связи нет, но вы же не пишете напрямую в железку ?
Если это фастлед, то она объявляет массив, и в массив можно не только писать , но и читать из него. А для яркости есть не только setBrightness , но и getBrightness
b707_2
22 Июл 2020
178
51
ну это и есть "запоминать в программе" :)
С чипов эту инфу не получить
DjafarT800
15 Дек 2019
19
Понял, спасибо.
Вот ваш код, добавил строчку только в void ledss() в начале int k = 0;
Без этой строки, на одну кнопку менялся цвет на рандом, но принажата на другую (которая цвет по умолчанию) свет выключается и больше ни на одну кнопку не реагирует, только перезапуск
#define PIN 3
int k = 0;
void setup()
ledss();
void ledss(){
int k = 0;
   FastLED.show();
       FastLED.show();
       delay(500);   //каждые 10мс увелияение на 1
    // turn LED on:
  FastLED.show();
  delay(1000);
    ledss();
1,332
О, еще один вариант расставления кажого 5-го светодиорда красным , а 7 синим.
for (int i=0;i<numled;i++)
strip[i] = CRGB::White;
if (i%5==0) strip[i] = CRGB::Red;
if (i%7==0) strip[i] = CRGB::Blue;
правда 35, 70 , 105 и т.д. светодиоды будут исключительно синими
Реакции: b707_2
b707_2
22 Июл 2020
178
51
нашел ошибку.
Добавленную Вами строчку уберите, она не нужна.
Ошибка в другом месте - в условиях цикла for в этой же процедуре
Напишите вот так и попробуйте:
for(k=0; k<255; k++)
DjafarT800
15 Дек 2019
19
а numled это откуда берется?
DjafarT800
15 Дек 2019
19
Работает как надо, спасибо, теперь буду знать
нашел ошибку.
Тоже работает, спасибо
