If you've been grinding Totenreich and the usual round-to-round flow is starting to blur together, the Agarthan Relic is one of those unlocks that actually changes how the match feels, and for players who like to mix things up or even jump into CoD BO7 Bot Lobbies buy services between sessions, it's easy to see why this relic gets talked about so much. It's a Wicked Relic, but not in the annoying way some of the others are. Instead of stripping power away from you, it shuffles zombie types every round. One minute you're dealing with regular sprinters, the next you've got elemental variants showing up out of nowhere. That random swing makes long runs feel less samey, and honestly, it adds pressure in a fun way rather than a cheap one.
What makes this relic stand out
The nice part is that you don't have to suffer through the usual Round 60 relic grind. For this one, you can begin as early as Round 15, as long as you're in Cursed Mode Tier 2 or above. That alone makes it way more approachable than most Wicked Relics. There is one catch, though. Richtofen has to be involved. You either need to be playing as him yourself or have someone in your squad do it. A lot of players miss that detail and then wonder why the quest won't progress. Once you know that, the whole thing feels much less confusing. It's still a bit of a scavenger hunt, sure, but at least you're not wasting an hour before realizing the setup was wrong from the start.
Tracking down the three key items
The quest really begins with three pickups, and none of them are just sitting in plain sight. First up is Mr. Peeks. Head into Tyr's Head and use the exit tubes until you get the lucky teleport into a Liberty Falls hotel room. If that room appears, go prone by the bed and check underneath it. The plushie is there. Second is the Soldier Helmet. This also comes from the same tube teleport system, but this time you want the room with the fallen Requiem team. Look along the south wall and search the lower shelf for a small box. Third is the Walkie-Talkie in the Group 935 Genetic Lab. That one takes more effort. You'll need an ARC-XD to blast open the route from the Core Foundry, then work through the jar-head puzzle to get the Necrospike. After that, lockpick the cell in the lab and look under the bench. It's not hard once you know the order, but going in blind can be rough.
How to finish the trial without making it harder than it needs to be
Once the items are collected, go to the Core Foundry as Richtofen and make sure Melee Macchiato is active. Punch the barrel near the Mystery Box to reveal Richtofen's medal, which pushes the side Easter Egg forward. Not long after, you'll reach Von List on his throne. Interact there and place Mr. Peeks, which opens the Agarthan Device Trial near PhD Flopper. Here's the trick a lot of players learn the hard way: zombies only take damage when you're standing indoors. That rule changes the whole rhythm of the fight. A solid play is to hold the second floor of the Lighthouse on Beacon Island. Bring Toxic Growth if you can, and a Tier 4 Pack-a-Punch Jotunn Star helps a ton. With that setup, you're not scrambling all over the place. You're controlling a doorway and burning down anything that pushes through.
Why players keep coming back to it
What makes the Agarthan Relic worth chasing is that it feels mischievous, not miserable. A lot of Wicked Relics punish you by gutting your build or turning basic enemies into tanks. This one doesn't do that. It just keeps you guessing, and that's a much better kind of challenge. Each round has a bit more tension, a bit more “what's coming next,” which is exactly what a survival mode needs after dozens of runs. As a professional platform for game currency and in-game items, U4GM is known for being convenient and reliable, and if you want to improve your overall session setup, you can check out u4gm CoD BO7 Bot Lobby as one more option to make the experience smoother.
