WiFi лампа-будильник. Обсуждение прошивки от vvip-68
vvip
18 Дек 2018
589
256
@Александр_Ава,
ну тогда приведите лог загрузки, сообщение, что загрузка выполнена успешно.
Или список ошибок, которые возникли при загрузке, раз по факту файловая система не загружена.
Александр_Ава
23 Фев 2025
@vvip,
esptool.py v4.5.1
Serial port COM6
Connecting....
Chip is ESP32-S3 (revision v0.2)
Features: WiFi, BLE
Crystal is 40MHz
MAC: 3c:dc:75:59:53:88
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Auto-detected Flash size: 16MB
Flash will be erased from 0x00670000 to 0x007effff...
Compressed 1572864 bytes to 727062...
Writing at 0x00670000... (2 %)
Writing at 0x006781d1... (4 %)
Writing at 0x006804d6... (6 %)
Writing at 0x006887d3... (8 %)
Writing at 0x00690b9a... (11 %)
Writing at 0x00698e3b... (13 %)
Writing at 0x006a0ffc... (15 %)
Writing at 0x006a9406... (17 %)
Writing at 0x006b15a5... (20 %)
Writing at 0x006c2201... (22 %)
Writing at 0x006ca1b9... (24 %)
Writing at 0x006d2559... (26 %)
Writing at 0x006da819... (28 %)
Writing at 0x006e2b88... (31 %)
Writing at 0x006eae70... (33 %)
Writing at 0x006f3620... (35 %)
Writing at 0x006fb849... (37 %)
Writing at 0x00703b2d... (40 %)
Writing at 0x0070bc51... (42 %)
Writing at 0x00713e5a... (44 %)
Writing at 0x0071c29e... (46 %)
Writing at 0x007246cc... (48 %)
Writing at 0x0072c8a5... (51 %)
Writing at 0x00734c37... (53 %)
Writing at 0x0073cccb... (55 %)
Writing at 0x00745243... (57 %)
Writing at 0x0074d5ce... (60 %)
Writing at 0x00755a59... (62 %)
Writing at 0x0075de54... (64 %)
Writing at 0x0076641d... (66 %)
Writing at 0x0076e6a0... (68 %)
Writing at 0x00776880... (71 %)
Writing at 0x0077eb4f... (73 %)
Writing at 0x00786d01... (75 %)
Writing at 0x0078ef8b... (77 %)
Writing at 0x007971c0... (80 %)
Writing at 0x0079f57a... (82 %)
Writing at 0x007a7aad... (84 %)
Writing at 0x007afec2... (86 %)
Writing at 0x007b82a5... (88 %)
Writing at 0x007c02ef... (91 %)
Writing at 0x007c85a4... (93 %)
Writing at 0x007d0a34... (95 %)
Writing at 0x007d8efe... (97 %)
Writing at 0x007e1235... (100 %)
Wrote 1572864 bytes (727062 compressed) at 0x00670000 in 11.0 seconds (effective 1142.7 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
Александр_Ава
23 Фев 2025
@vvip,
Leaving...
[SPIFFS] data : C:\Users\...\LedPanelWiFi-main\firmware\LedPanelWiFi_v1.14\data
[SPIFFS] start : 6750208
[SPIFFS] size : 1536
[SPIFFS] page : 256
[SPIFFS] block : 4096
/web/a/i/32.svg.gz
/web/a/i/32c3.svg.gz
/web/a/i/32c3m.png
/web/a/i/32s2.svg.gz
/web/a/i/32s2m.png
/web/a/i/32s3.svg.gz
/web/a/i/32s3m.png
/web/a/i/node.svg.gz
/web/a/i/w.svg.gz
/web/a/i/wemos.svg.gz
/web/a/l/eng.json.gz
/web/a/l/esp.json.gz
/web/a/l/lat.json.gz
/web/a/l/pol.json.gz
/web/a/l/rus.json.gz
/web/a/tz-eng.json.gz
/web/a/tz-esp.json.gz
/web/a/tz-lat.json.gz
/web/a/tz-pol.json.gz
/web/a/tz-rus.json.gz
/web/chunk-3IM54G3T.js.gz
/web/chunk-3MQREIDX.js.gz
/web/chunk-46AJKIN2.js.gz
/web/chunk-4HEXTZCI.js.gz
/web/chunk-4J3ESD4K.js.gz
/web/chunk-5QI2BH75.js.gz
/web/chunk-5SSDKWJM.js.gz
/web/chunk-64ZNTZPC.js.gz
/web/chunk-7KR3THG5.js.gz
/web/chunk-7XSEAOSB.js.gz
/web/chunk-AYYGXFO5.js.gz
/web/chunk-BVJUBOFL.js.gz
/web/chunk-CJQS6RUM.js.gz
/web/chunk-FJL3U3PQ.js.gz
/web/chunk-GTMMLIZQ.js.gz
/web/chunk-H2GZLP63.js.gz
/web/chunk-HNDY2MV5.js.gz
/web/chunk-IZGRH33U.js.gz
/web/chunk-JI7WS5WA.js.gz
/web/chunk-JOI7FNNI.js.gz
/web/chunk-JUPGJJQD.js.gz
/web/chunk-JVDRGJXS.js.gz
/web/chunk-M6HBMXOX.js.gz
/web/chunk-MDLLLR26.js.gz
/web/chunk-OMYIPD4K.js.gz
/web/chunk-PWLZXKIN.js.gz
/web/chunk-PWNYKSMO.js.gz
/web/chunk-QAFUC2OW.js.gz
/web/chunk-QLME2ZFM.js.gz
/web/chunk-RFY37QB5.js.gz
/web/chunk-SQHOVU6R.js.gz
/web/chunk-TAXBKAOE.js.gz
/web/chunk-VAHO6XIR.js.gz
/web/chunk-VLFI67PD.js.gz
/web/chunk-WGX3LEEA.js.gz
/web/chunk-ZFTF2I7M.js.gz
/web/favicon.ico.gz
/web/index.html.gz
/web/main-Z3FRND4Y.js.gz
/web/media/m-CIXJEH54.woff2
/web/media/w-OL2QU3PE.svg.gz
/web/polyfills-EONH2QZO.js.gz
/web/styles-4OBCSMOR.css.gz
[SPIFFS] upload : C:\Users\...\AppData\Local\Temp\arduino_build_968193/LedPanelWiFi_v1.14.spiffs.bin
[SPIFFS] address: 6750208
[SPIFFS] port : COM6
[SPIFFS] speed : 921600
[SPIFFS] mode : dio
[SPIFFS] freq : 80m
ВладимирЗА
24 Май 2023
здравствуйте, vvip. Спасибо за Вашу работу! Скетч, с виду, навороченный и, наверно, результат соответствующий. НО...! Или я не понял, или что-то не так делаю..? Бьюсь с NodeMCU ESP8266 и матрица 14 столбиков по 48 диодов в высоту (елка такая из пластиковых трубок). Больше ничего в железе нет. Не работаю с приложением. Просто хочу чтобы елка в автономе перебирала максимум эффектов без игр, погоды, часов. Ничего не получается. После загрузки работает порядка 300 диодов как попало. Все настройки сделал для варианта "0", тип - параллель. P.S. Версия 1.12 работает нормально. Но в ней мало подходящих для елки эффектов. Что я не так делаю? Подскажите пожалуйста.
vvip
18 Дек 2018
589
256
@ВладимирЗА, из вашего описания проблемы - практически ничего не понятно.
300 диодов - возможно неисправны диоды и линия где-то оборвана. Или в настройках сконфигурировано только 300 диодов. Других причин не вижу.
Что такое "как попало" - тоже не поддается классификации. Причины - например неверно сконфигурирована матрица. Или оборван сигнальный провод и/или ловит помехи. Или неверные версии ядра / библиотек (не те, что рекомендованы в проекте). Или напряжение питания не укладывается в допустимый диапазон. Или шумящий источник питания дает наводки.
Это все, что могу ответить. Как минимум интересно посмотреть что выводится в мониторе порта сразу после (пере)загрузки микроконтроллера. Вы ведь даже версию используемой прошивки не указали.
В общем - на бестолковый вопрос столь же бестолковый ответ.
ВладимирЗА
24 Май 2023
Спасибо за ответ. Прошивка 1.13. Загрузил вашу разработку версии 1.14. Где-то в ней нашел вариант повторной прошивки ESP. Указал в настройках инструменты Erase Flash - "All flash Contents". И чудо случилось - прошивка заработала (имею ввиду 1.13). Все здорово работает на моем варианте исполнения. Не хватает эффектов движущихся колец, спиралей бегущих столбцов и т.п. для елки. Огромное Вам спасибо за продвижение сего проекта!
Victan
20 Ноя 2023
Спасибо за проект, лично я матрицу вставил в заднюю часть стеклоблока, и между матрицей и блоком вставил зеркальную тонировку, получается достаточно красиво, стеклоблок еще как кристал немного играет цветами текущей анимации. Схема прячется сзади в крышке распечатаной на 3д принтере. По невероятной случайности стандартные стеклоблоки имеют размер четко под матрицу 16 ×16.
Есть одна проблема я сделал автосмену режимов ,по расписанию все меняется, днем часы с погодой а вечером камин. Но матрица почему то в какой то момент перестает показывать погоду, подключится к матрице невозможно, но автосмена режимов продолжает работать, ощущение что матрица уходит в спящий режим какойто. Стоит ее перезагрузить и все становится в порядке, появляется погода и подключиться к ней можно. Через какоето время проблема повторяется, подскажите пожалуйста в чем может быть проблема.
P.S Есть еще варианты заклейки матрицы белой и металической пленкой и так и так неплохо но с тонировкой контраст лучше, и негорящих пикселей практически не видно, а за счет зеркальности кажется что стеклоблок насквозь прозрачный. Тонировка 80% яркости поглощает, но в более светлой смысоа нет так как уже просвечивается. Хотел прикрепить шаблон для резки на плотере но форум не дает этот формат. В копицентрах сейчас большой выбор виниловых пленок в том числе и всяких голографических можно еще играться и этим параметром. Если не нужны часы и погода можно купить стеклоблоки типа волна и так далее их красивых сейчас очень много тогда все эфекты выглядят еще интересней. Берите матрицу и повербанк в магазин стеклоблоком приставляйте и смотрите какой лучше купить) Сейчас тренд на светильники из стеклоблоков но они простые все с подсветуой снизу обычной RGB лентой и цены зависят от жадности продавца а такого варианта на рынке я ненашел. 20260120_205155.jpg20260120_205358.jpg avito-1765043517452-shot.jpgavito-1765043514361-shot.jpg20251208_122940.jpg20251207_224608.jpg20251208_122658.jpg
Реакции: Binar и Divin
vvip
18 Дек 2018
589
256
@Victan, хорошая реализация.
Раз продолжает светить и что-то изображать - значит в спящий режим не уходит. Да и нет там его.
Если теряет погоду и невозможно подключиться - пропадает подключение к сети.Причин я не знаю. У меня такое только на одном устройстве бывает. Оно находится довольно далеко от роутера и сигнал слабый, да еще роутер периодически из сети пропадает. Думаю с этим всё связано.
igoryanic
9 Фев 2026
Доброго времени суток.Не пинайте сильно чайника,есть вопрос по не решенному делу.
Дело такое-проэкт LedPanelWiF ,плата esp8266,кампиляция,загрузка скетча,точка доступа IP 192.168.4.1 сеть PanelAP =все норм.Вэбинтерфейс -настройка сети -ввожу параметры своей сети -имя-пароль сети -ip (стационарного роутера нет-имею телефон андроид -как точку доступа на раздаче интернета)плата к телефону подключается как не известное устройство -отображается только мак адрес-вопрос такой -помогите-как узнать ip платы esp8266(по инструкций нужно ввести уже ip устройства далее в браузере - которое подключится к телефону-чтобы открылся вэбинтерфейс для дальнейшего пользования)
Подскажите где искать - может информация должна быть в мониторе порта-при подключений к компу или гдето еще-буду благодарен за помощь.
vvip
18 Дек 2018
589
256
@igoryanic, именнно - при старте платы в монитор порта выводится ее IP адрес.
Ну или если плата подключена к матрице - 4-х кратное нажатие на кнопку отображает на матрице IP адрес, полученный платой.
Вообще, плата должна использовать именно тот IP, который вы (как написано выше) прописали при настройке ей для использования.
@igoryanic, и может быть такой момент - плата никогда не тестировалась на предмет подключения к телефону, как к точке доступа. В том смысле, что получив указанный желаемый адрес (например, от фонаря -192.145.12.12)она будет в настройках использовать адрес 192.145.12.1 как шлюз, куда отправляются все пакеты. А если пара телефон как мастер-плата как slave работает как-то по другому в плане сетевой конфигурации и настроек - то т пакеты могут не бегать как нужно и никакого интерфейса вы не увидите.
Адрес шлюза - формируется из адреса платы, последняя цифра заменяется на 1 (обычно) или 100 - в зависимости от заданного значения константы GTW. Возможно при такой конфигурации в качестве GTW нужно указывать последнюю цифру IP телефона, чтобы телефон сам как шлюз выступал... Но еще раз - всё это теоретизирование, потому как использование платы в таком варианте не предполагалось и не тестировалось.
Александр_Ава
23 Фев 2025
@igoryanic, нажмите и удерживайте иконку включения точки доступа на телефоне и Вы попадёте в настройки этой самой точки доступа. Если панель уже подключена к телефону, то она должна быть в списке подключенный устройств. Просто нажмите на неё и Вы увидите информацию о плате. Это и mac-адрес и IP-адрес и ещё некоторые параметры.
Игорь К.
25 Дек 2023
65
Добрый день, Автор и форумчане. Всем спасибо еще раз за помощь в прошлом 13 проекте. Получил esp32 в январе, потому на НГ не успел сделать 14 версию. Решил не ждать целый год, скомпилировал и залил прошивку v1.14.2025.1012. Оставил только SD-Shield, Реле и Сенсорную кнопку. Панель на 2024 диода (46х44).
1.В сопроводительной карточке к светодиодной гирлянде значится GRB, проверил через WLED - GRB. Выставил в скетче в a_def_hard.h - GRB. Панель заработала сразу, за WEB-интерфейс Спасибо - подробно и почти интуитивно понятно! Зашитые эффекты работают, пробежался по каждому. Создал из скачанных пяти gif через JINX файлы с расширением .out, обрезал до 30 сек в JINX FRAMER, записал на карточку папку 46x44 с пятью эффектами. Включил SD-эффект и... неприятно удивился - цвета эффектов не те: красный огонь - зеленый! В настройках, в Оборудовании заменил GRB на RGB - красный огонь - стал красным. Вернулся к зашитому в контроллер эффекту Огонь - он зеленый. Проверил настройки в JINX - стоит GRB, открыл в JINX FRAMER созданные файлы - открывает цвета верно, если стоит GRB. Не могу понять где что не выставил? Прошу помощи.
2. Еще момент. В SD-эффекте выставляю Последовательно, ждлу когда через 30 сек произойдет переключение эффекта на следующий, увы, продолжает крутиться первый... минуту, две... Как заставить перебираться эффекты на карточке?
3. Наблюдал несколько раз такое: нажимаю SD-эффект, запускается эффект с SD-карты, через некоторое время обращаю внимание, что на панели не эффект с SD, а эффект из контроллера. Как выбрать только эффекты с карточки, без переключения на эффектиы контроллера?
Буду признателен за помощь.
P.S. про свое общание выложить исходники gif и результат out не забыл. Как раз сейчас по-тихоньку займусь интересными gif-ками, на новой матрице 46х44 должны смотреть отлично.
vvip
18 Дек 2018
589
256
@Игорь К.,
Порядок цветов в эффекте SD-карта задается в программе Jinx, когда вы "снимаете" ролики. Там нужно правильно настроить. Ну и сделать / прогнать пробный ролик, чтобы убедится, что все ок. Читайте в Wiki про создание роликов из Jinx - там вроде даже в картинках было. Впрочем, утилита JinxFramer насколько я помню, имеет фичу обрезки и перекодировки роликов. Обрезать вам не нужно, а вот прогнать через утилиту ролики для правильной перекодировки цвета - вполне возможно.
Эффекты с карточки вроде бы должны переключаться так же как и встроенные - по заданному таймеру.За некоторым исключением - там в настройках есть чекбоксы переключения поведения для длинных и коротких роликов. То есть если ролик короче указанного для эффектов времени - выбор - либо переключиться на следующий по окончанию ролика, либо повторять его пока не выйдет время. Для длинных роликов примерно то же - либо прерывать по истечению времени эффекта, либо доигрывать до конца и только потом переключаться дальше.
Про эффекты именно с SD-карты.Там нет возможности, чтобы использовать эффекты только с SD-карты. Чтобы только с карты - нужно отключить все "встроенные". В настройках самого эффекта SD-карты - "рандомно" - каждый раз, когда приходи очередь включиться эффекту SD-карта - воспроизводится случайный ролик с карточки. Если последовательно - то каждый раз, когда приходи очередь включиться эффекту SD-карта включится следующий по списку ролик.
Также влияние общего флажка "Случайно" / "Последовательно" - эффекты перебираются в указанной последовательности и когда очередь доходит до эффекта SD-карта и ы его настройках стит режим "Последовательно" - тогда будут перебираться последовательно все ролики, имеющиеся на флэшке. Вот так это работает. Как самый распространенный / востребованный сценарий работы.
И, насколько я помню для JINX надо всегда выбирать RGB. Потому что этот порядок цветов сохраняется в ролике. А когда FastLED отправляет байты ролика в контроллер -он сам переставляет байты цветов в порядке, указанном в настройках. А так получается, что сначала JINX переставляет байты, потом контроллер еще раз переставляет и в результате получается неправилный цвет...
Игорь К.
25 Дек 2023
65
vvip, доброй ночи. Спасибо за отклик.
Как я писал в своем 1 вопросе в JINX выставлялись все верные параметры, вкл. GRB, проверил еще раз. Обрезал длину ролика в JINX FRAMER - цвета в программе воспроизводились верно, если выставлял GRB.
Предложенное Вами, в последнем абзаце, решение завтра попробую. Нигде не читал про эту особенность JINX. Попробую. Да, прямо сейчас. И отпишусь.
vvip, Вы правы! Надо себе записать - в JINX и FRAMER выставлять RGB. М-да, зря я несколько десятков роликов сделал. Завтра переделывать. Ну, ничего - главное конечный результат.
Про режимы эффектов, описанное Вами, буду вникать завтра. А сейчас - спать!
Доброй ночи.
Спасибо.
SergeL
29 Янв 2020
Доброго дня все. Подскажите варнинги при компиляции можно проигнорировать или все таки это не есть хорошо?
In file included from E:\LedPanelWiFi-WEB\firmware\LedPanelWiFi_v1.14\a_def_hard.h:630,
from E:\LedPanelWiFi-WEB\firmware\LedPanelWiFi_v1.14\LedPanelWiFi_v1.14.ino:350:
E:\LedPanelWiFi-WEB\firmware\LedPanelWiFi_v1.14\a_def_lang.h:39:6: warning: multi-character character constant [-Wmultichar]
39 | #if (LANG == 'RUS')
E:\LedPanelWiFi-WEB\firmware\LedPanelWiFi_v1.14\a_def_lang.h:39:14: warning: multi-character character constant [-Wmultichar]
Так на все языки
In file included from c:\Users\user\Documents\Arduino\libraries\FastLED\src/FastLED.h:75,
from E:\LedPanelWiFi-WEB\firmware\LedPanelWiFi_v1.14\a_def_hard.h:651,
c:\Users\user\Documents\Arduino\libraries\FastLED\src/fastspi.h:157:23: note: '#pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output'
157 | # pragma message "No hardware SPI pins defined. All SPI access will default to bitbanged output"
vvip
18 Дек 2018
589
256
@SergeL, Варнинги при компиляции можно проигнорировать.
По большей части они информационные, с частью вообще ничего нельзя сделать. Другая часть варнингов может вообще относиться к коду внутри сторонних библиотек, сообщая о нарушении каких-то общепринятых правил программирования и или / потенциальных проблемах. Особенно много их в FastLED. Не будете же вы править код FastLED, к примеру?...
На работу программы они не влияют.
Dimonn68
27 Фев 2025
22
Привет пытался прошить бинами для s3, нехочет подключатся к WiFi точку доступа создает, дальше тишина, может кто подскажет в чем дело, всем спасибо.
Следом прошил радио все нормально, подумал что esp шка негодная нет все нормально, все работает.
AnCore
27 Янв 2020
473
197
@Dimonn68, я, видимо, что-то не так с настройками для esp32s3 сделал перед экспортом бинарников, сегодня исправлю и обновлю архив, а сюда могу скинуть вариант под вашу конфигурацию (если уточните, что отключено в прошивке, что включено)
Dimonn68
27 Фев 2025
22
Спасибо,хочу лампу собрать, матрица стандартная 16x16 из переферии кнопка и tm 1637, извините а вы в какой проге компилируете, если для VSC есть, может выложите, спасибо.
У меня vsc для радио настроен, версия ядра 2.017, выше пробывал, потом, надо все заново устанавливать, а так в ней все быстро, хотя год назад в ардуине все у меня получалось, собирал на 8266, Спасибо что отозвались.
Dimonn68
27 Фев 2025
22
An Core спасибо вам за bin файлы, ничего не получается, попробовал в Ардуино, у меня ругается на вкладке effects2, строка 170,171, может подскажите какую фаст лед версию установить, ядро поставил 2.017, fast led 3.06. Спасибо.
AnCore
27 Янв 2020
473
197
Т.е. прошили плату бинарниками и всё равно не подключается? Я вообще проверил, сначала прошил по проводу, поднялась точка доступа, далее указал логин и пароль wifi, плата подключилась к wifi. Далее стер всё через flash download и прошил бинарниками, подключился к точке доступа, далее к wifi... Ядро esp32 2.0.17, Fastled 3.6.0
Почему возникают ошибки в ардуино? Если тут F:\AnCore\Documents\Arduino\libraries есть библиотека FastLED, удалите её, пусть она будет тут
C:\Program Files (x86)\Arduino\libraries
Dimonn68
27 Фев 2025
22
да прошил бинарниками нехочет подключатся.както было такое буд то бы файловая система не загрузилась.хорошо буду дальше ардуину мучать.спасибо .если что обращусь.если непротив.
