ESP, IoT ESP8266, проблема с компиляцией скетча
Delfin888
30 Сен 2020
Arduino: 1.8.14 Hourly Build 2020/10/09 12:33 (Windows 10), Плата:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (1M SPIFFS), v2 Higher Bandwidth (no features), Disabled, None, Sketch + WiFi Settings, 115200"
C:\Users\Garazh\Documents\arduino-nightly-windows\arduino-nightly\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\Garazh\Documents\arduino-nightly-windows\arduino-nightly\hardware -hardware C:\Users\Garazh\AppData\Local\Arduino15\packages -tools C:\Users\Garazh\Documents\arduino-nightly-windows\arduino-nightly\tools-builder -tools C:\Users\Garazh\Documents\arduino-nightly-windows\arduino-nightly\hardware\tools\avr -tools C:\Users\Garazh\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\Garazh\Documents\arduino-nightly-windows\arduino-nightly\libraries -libraries C:\Users\Garazh\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,ssl=all,eesz=4M1M,ip=hb2n,dbg=Disabled,lvl=None____,wipe=sdk,baud=115200 -vid-pid=10C4_EA60 -ide-version=10814 -build-path C:\Users\Garazh\AppData\Local\Temp\arduino_build_75206 -warnings=all -build-cache C:\Users\Garazh\AppData\Local\Temp\arduino_cache_422428 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.python.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\python\3.7.2-post1 -prefs=runtime.tools.python-3.7.2-post1.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\python\3.7.2-post1 -verbose C:\Users\Garazh\Documents\Downloads\gunner47_v1.5.82in1\GyverLamp-master\firmware\gunner47_v1.5.82in1\gunner47_v1.5.82in1.ino
C:\Users\Garazh\Documents\arduino-nightly-windows\arduino-nightly\arduino-builder -compile -logger=machine -hardware C:\Users\Garazh\Documents\arduino-nightly-windows\arduino-nightly\hardware -hardware C:\Users\Garazh\AppData\Local\Arduino15\packages -tools C:\Users\Garazh\Documents\arduino-nightly-windows\arduino-nightly\tools-builder -tools C:\Users\Garazh\Documents\arduino-nightly-windows\arduino-nightly\hardware\tools\avr -tools C:\Users\Garazh\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\Garazh\Documents\arduino-nightly-windows\arduino-nightly\libraries -libraries C:\Users\Garazh\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,ssl=all,eesz=4M1M,ip=hb2n,dbg=Disabled,lvl=None____,wipe=sdk,baud=115200 -vid-pid=10C4_EA60 -ide-version=10814 -build-path C:\Users\Garazh\AppData\Local\Temp\arduino_build_75206 -warnings=all -build-cache C:\Users\Garazh\AppData\Local\Temp\arduino_cache_422428 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.python.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\python\3.7.2-post1 -prefs=runtime.tools.python-3.7.2-post1.path=C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\tools\python\3.7.2-post1 -verbose C:\Users\Garazh\Documents\Downloads\gunner47_v1.5.82in1\GyverLamp-master\firmware\gunner47_v1.5.82in1\gunner47_v1.5.82in1.ino
Using board 'nodemcuv2' from platform in folder: C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2
Using core 'esp8266' from platform in folder: C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2
Detecting libraries used...
"C:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Temp\\arduino_build_75206/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=1460 -DLWIP_FEATURES=0 -DLWIP_IPV6=0 -DARDUINO=10814 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "C:\\Users\\Garazh\\AppData\\Local\\Temp\\arduino_build_75206\\sketch\\gunner47_v1.5.82in1.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for ESP8266WebServer.h: [[email protected]]
ResolveLibrary(ESP8266WebServer.h)
-> candidates: [[email protected]]
"C:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Temp\\arduino_build_75206/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=1460 -DLWIP_FEATURES=0 -DLWIP_IPV6=0 -DARDUINO=10814 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\ESP8266WebServer\\src" "C:\\Users\\Garazh\\AppData\\Local\\Temp\\arduino_build_75206\\sketch\\gunner47_v1.5.82in1.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for ESP8266WiFi.h: [[email protected]]
ResolveLibrary(ESP8266WiFi.h)
"C:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Garazh\\AppData\\Local\\Temp\\arduino_build_75206/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=1460 -DLWIP_FEATURES=0 -DLWIP_IPV6=0 -DARDUINO=10814 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\nodemcu" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\ESP8266WebServer\\src" "-IC:\\Users\\Garazh\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\Garazh\\AppData\\Local\\Temp\\arduino_build_75206\\sketch\\gunner47_v1.5.82in1.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for platforms/esp/8266/led_sysdefs_esp8266.h: []
ResolveLibrary(platforms/esp/8266/led_sysdefs_esp8266.h)
-> candidates: []om C:\Users\Garazh\AppData\Local\Temp\arduino_build_75206\sketch\FastLED.h:41:0,
from C:\Users\Garazh\Documents\Downloads\gunner47_v1.5.82in1\GyverLamp-master\firmware\gunner47_v1.5.82in1\gunner47_v1.5.82in1.ino:218:
led_sysdefs.h:29:52: fatal error: platforms/esp/8266/led_sysdefs_esp8266.h: No such file or directory
#include "platforms/esp/8266/led_sysdefs_esp8266.h"
compilation terminated.
Используем библиотеку ESP8266WebServer версии 1.0 из папки: C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WebServer
Используем библиотеку ESP8266WiFi версии 1.0 из папки: C:\Users\Garazh\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi
exit status 1
1.8.14 установил , та же ерунда.
Что за причина может, что понималось всё пробовал.
кто понимает дайте подсказку !
Tygra
31 Май 2019
Друзья, помогите с проблемой на этапе компиляции.
Arduino: 1.8.13 (Windows 8.1), Плата:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Higher Bandwidth, Disabled, None, Only Sketch, 921600"
In file included from C:\Users\Ivan\Downloads\Compressed\gunner47_v1.5\GyverLamp-master\firmware\gunner47_v1.5\gunner47_v1.5.ino:144:0:
C:\Users\Ivan\Documents\Arduino\libraries\FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.002.009
In file included from C:\Users\Ivan\Documents\Arduino\libraries\FastLED/FastLED.h:65:0,
C:\Users\Ivan\Documents\Arduino\libraries\FastLED/fastspi.h:115:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
C:\Users\Ivan\Downloads\Compressed\gunner47_v1.5\GyverLamp-master\firmware\gunner47_v1.5\button.ino: In function 'void buttonTick()':
button:159:19: error: 'class GButton' has no member named 'getHoldClicks'
switch (touch.getHoldClicks())
Несколько библиотек найдено для "FastLED.h"
Используется: C:\Users\Ivan\Documents\Arduino\libraries\FastLED
Не используется: C:\Program Files (x86)\Arduino\libraries\FastLED
Не используется: C:\Program Files (x86)\Arduino\libraries\FastLED-3.2.9
Несколько библиотек найдено для "NTPClient.h"
Используется: C:\Program Files (x86)\Arduino\libraries\NTPClient
Не используется: C:\Program Files (x86)\Arduino\libraries\NTPClient-master
exit status 1
Tygra
31 Май 2019
Не та версия библиотеки GyverButton, поставь ту, что в архиве проекта.
прямо с архива кидаю библиотеку. Уже переустановил ардуину. все равно таже ошибка
вот этот проект
сейчас попробовал от gunner 47 v1.5_2 поставил , удалил те библиотеки, вставил из архива. Ругается также . Я уже не знаю , что делать.
Сейчас попробовал gyvermaster, тоже самое. Уже все. не знаю, что делать, при том что две лампы у меня уже работают собранные. хотел еще одну сделать.
Александр Симонов
2 Авг 2018
741
208
вот этот проект
Давай конкретные ссылки на архивы, которые качаешь
Александр Симонов
2 Авг 2018
741
208
Это изначальная, эту тоже пробовал., эту от гайвера тоже пробовал. Библиотеки удалял везде полностью, и программ файлз, и локал.
От Гайвера нормально собирается и в ней не используется метод getHoldClicks(), так что ошибка у тебя не может быть той же самой.
"Изначальная" прошивка у меня компилируется. В ней getHoldClicks используется, и в приложенной библиотеке GyverButton этот метод определен.
Tygra
31 Май 2019
Тогда что может быть у меня? Есть варианты.?Просто я папку guiverbutton уже менял и удалял и другие пробовал подсовывать. Не помогает. Не вижу пути решения, ввиду не полного знания вопроса.
Александр Симонов
2 Авг 2018
741
208
Вариантов нет, у тебя установлена не та версия GyverButton.
Для начала переустанови Arduino IDE ещё разок и потом ничего и никогда не трогай в C:\Program Files (x86)\Arduino\libraries\, даже если Гайвер тебе говорит иначе. Все библиотеки забрасывай в C:\Users\Ivan\Documents\Arduino\libraries\
Потом определись с прошивкой. Разным прошивкам нужны разные версии GyverButton. Все необходимые библиотеки в архивах есть, забрасывай их в папку C:\Users\Ivan\Documents\Arduino\libraries\.
Когда всё проделаешь, если будут ошибки, показывай. Только точно скажи, какую прошивку пытаешься компилировать.
Реакции: Tygra
Tygra
31 Май 2019
Блин, все скомпилилось. Я и не подозревал, что библиотеки нужно кидать в документы. Стояла раньше семерка, все было хорошо, потом поставил восьмерку, она там чето с правами и разрешениями мутит. Наверное, от этого ардуино и не видел эти библиотеки в програм файлс. Я так думаю.. Огромная благодарность за наставление на путь решения проблемы!
Evgen1986
15 Ноя 2020
37
Добрый всем день! Помогите пожалуйста добрые люди. Делаю гирлянду, но увы выскакивает ошибка:
In file included from C:\ard\GyverMatrixOS_v1.12\GyverMatrixOS_v1.12.ino:138:0:
C:\Program Files (x86)\Arduino\libraries\FastLED-3.2.9/FastLED.h:14:21: note: #pragma message: FastLED version 3.002.009
In file included from C:\Program Files (x86)\Arduino\libraries\FastLED-3.2.9/FastLED.h:65:0,
C:\Program Files (x86)\Arduino\libraries\FastLED-3.2.9/fastspi.h:115:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
In file included from C:\Program Files (x86)\Arduino\libraries\FastLED-3.2.9/FastLED.h:48:0,
C:\Program Files (x86)\Arduino\libraries\FastLED-3.2.9/fastpin.h: In instantiation of 'class FastPin<6u>':
C:\Program Files (x86)\Arduino\libraries\FastLED-3.2.9/platforms/esp/8266/clockless_esp8266.h:21:49: required from 'class ClocklessController<6, 20, 50, 30, (EOrder)66u, 0, false, 50>'
C:\Program Files (x86)\Arduino\libraries\FastLED-3.2.9/chipsets.h:571:7: required from 'class WS2812Controller800Khz<6u, (EOrder)66u>'
C:\Program Files (x86)\Arduino\libraries\FastLED-3.2.9/FastLED.h:103:52: required from 'class WS2812<6u, (EOrder)66u>'
C:\Program Files (x86)\Arduino\libraries\FastLED-3.2.9/FastLED.h:302:39: required from 'static CLEDController& CFastLED::addLeds(CRGB*, int, int) [with CHIPSET = WS2812; unsigned char DATA_PIN = 6u; EOrder RGB_ORDER = (EOrder)66u]'
C:\ard\GyverMatrixOS_v1.12\GyverMatrixOS_v1.12.ino:209:63: required from here
C:\Program Files (x86)\Arduino\libraries\FastLED-3.2.9/fastpin.h:207:2: error: static assertion failed: Invalid pin specified
static_assert(validpin(), "Invalid pin specified");
exit status 1
Ошибка компиляции для платы WeMos D1 R1.
Библиотеки разархивировал скопировал и сбрасываю:
Но в итоге ничего не получается, все по инструкции и с бубном уже второй месяц. ( Помогите, что не так?
Evgen1986
15 Ноя 2020
37
Если у тебя wemos d1 mini, то выбери её в платах
не помогло((((
exit status 1
Ошибка компиляции для платы LOLIN(WEMOS) D1 R2 & mini.
Александр Симонов
2 Авг 2018
741
208
не пойму где это(
Да, пардон, ориентировался на сообщение об ошибке.
В общем, надо сначала выбрать правильный микронтроле в скетче, у вас сейчас AVR выбран наверняка
Реакции: Ramzes_XXIV
Evgen1986
15 Ноя 2020
37
везде ищу... не знаю где его менять, можете скрин прислать... пожалуйста
980
не надо его "везде искать", в основном скетче ищите. Скрин вам дали... примерно строка 80-100
Вот прям такой код как @Александр Симонов показал
Вместо того чтоб 2 месяца перепаивать, может стоило начальные уроки по программированию почитать?
Evgen1986
15 Ноя 2020
37
Извините меня, если я вас напрягаю... изучил полностью весь материал, который автор выложил на сайте. Сделал абсолютно все как было указано и в итоге потратил уму времени и не мало денег, но в итоге результата - 0. заниматься программированием - нет спасибо на это надо быть программистом. понятия как скэтч мне не известно(
Evgen1986
15 Ноя 2020
37
поставил 1
далее ошибка:
GyverMatrixOS_v1.12:1:1: error: stray '\320' in program
пробую/*
GyverMatrixOS_v1.12:1:1: error: stray '\277' in program
GyverMatrixOS_v1.12:1:1: error: stray '\321' in program
GyverMatrixOS_v1.12:1:1: error: stray '\200' in program
GyverMatrixOS_v1.12:1:1: error: stray '\276' in program
GyverMatrixOS_v1.12:1:1: error: stray '\261' in program
GyverMatrixOS_v1.12:1:1: error: stray '\203' in program
GyverMatrixOS_v1.12:1:1: error: stray '\216' in program
exit status 1
