Library Manager: EspSoftwareSerial@7.0.0+sha.56d19bf has been installed!
Library Manager: Installing git+https://github.com/vortigont/EmbUI_int.git
git version 2.38.1
Cloning into '/Users/user/.platformio/.cache/tmp/pkg-installing-e91t_m86'...
remote: Enumerating objects: 109, done.
remote: Counting objects: 100% (109/109), done.
remote: Compressing objects: 100% (92/92), done.
remote: Total 109 (delta 20), reused 73 (delta 14), pack-reused 0
Receiving objects: 100% (109/109), 399.11 KiB | 2.63 MiB/s, done.
Resolving deltas: 100% (20/20), done.
Library Manager: EmbUI@2.7.0+sha.f6ce61c has been installed!
Library Manager: Resolving dependencies...
Library Manager: Installing bblanchon/ArduinoJson @ *
Unpacking [####################################] 100%
Library Manager: ArduinoJson@6.20.1 has been installed!
Library Manager: Installing git+https://github.com/vortigont/ESPAsyncWebServer#hotfixes
git version 2.38.1
Cloning into '/Users/user/.platformio/.cache/tmp/pkg-installing-t4cjyvyo'...
remote: Enumerating objects: 62, done.
remote: Counting objects: 100% (62/62), done.
remote: Compressing objects: 100% (55/55), done.
remote: Total 62 (delta 3), reused 36 (delta 0), pack-reused 0
Receiving objects: 100% (62/62), 271.61 KiB | 2.06 MiB/s, done.
Resolving deltas: 100% (3/3), done.
Library Manager: AsyncWebServer@1.2.3+sha.55ebf03 has been installed!
Library Manager: Installing me-no-dev/AsyncTCP @ ^1.1.1
Library Manager: AsyncTCP@1.1.1 has been installed!
Library Manager: Installing marvinroger/AsyncMqttClient @ *
Library Manager: AsyncMqttClient@0.9.0 has been installed!
Library Manager: Installing arkhipenko/TaskScheduler @ *
Library Manager: TaskScheduler@3.7.0 has been installed!
Library Manager: Installing ESP32SSDP @ *
Library Manager: ESP32SSDP@1.2.1 has been installed!
Library Manager: Installing git+https://github.com/charno/FTPClientServer
git version 2.38.1
Cloning into '/Users/user/.platformio/.cache/tmp/pkg-installing-6rdti78d'...
remote: Enumerating objects: 22, done.
remote: Counting objects: 100% (22/22), done.
remote: Compressing objects: 100% (18/18), done.
remote: Total 22 (delta 2), reused 8 (delta 0), pack-reused 0
Receiving objects: 100% (22/22), 32.94 KiB | 1.10 MiB/s, done.
Resolving deltas: 100% (2/2), done.
Library Manager: FTPClientServer@0.0.0+sha.f3521ff has been installed!
Library Manager: Installing git+https://github.com/vortigont/LinkedList
git version 2.38.1
Cloning into '/Users/user/.platformio/.cache/tmp/pkg-installing-_o6acct3'...
remote: Enumerating objects: 25, done.
remote: Counting objects: 100% (25/25), done.
remote: Compressing objects: 100% (20/20), done.
remote: Total 25 (delta 0), reused 14 (delta 0), pack-reused 0
Receiving objects: 100% (25/25), 14.96 KiB | 1.36 MiB/s, done.
Library Manager: LinkedList@1.5.0+sha.9945584 has been installed!
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/wemos_d1_mini32.html
PLATFORM: Espressif 32 (3.5.0) > WeMos D1 MINI ESP32
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-arduinoespressif32 @ 3.10006.210326 (1.0.6)
- tool-esptoolpy @ 1.30100.210531 (3.1.0)
- toolchain-xtensa32 @ 2.50200.97 (5.2.0)
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 47 compatible libraries
Scanning dependencies...
Dependency Graph
|-- DFRobotDFPlayerMini @ 1.0.5+sha.bc15936
|-- microDS18B20 @ 3.10.0+sha.333011c
|-- GyverButton @ 3.8.0+sha.9b161d4
|-- FastLED @ 3.5.0+sha.3d2ab78
| |-- EspSoftwareSerial @ 7.0.0+sha.56d19bf
| |-- SPI @ 1.0
|-- EmbUI @ 2.7.0+sha.f6ce61c
| |-- ArduinoJson @ 6.20.1
| |-- AsyncMqttClient @ 0.9.0
| | |-- AsyncTCP @ 1.1.1
| |-- TaskScheduler @ 3.7.0
| |-- ESP32SSDP @ 1.2.1
| | |-- ESP32 Async UDP @ 1.0.0
| | |-- WiFi @ 1.0
| |-- LinkedList @ 1.5.0+sha.9945584
| |-- AsyncTCP @ 1.1.1
| |-- ESP Async WebServer @ 1.2.3+sha.55ebf03
| | |-- AsyncTCP @ 1.1.1
| | |-- FS @ 1.0
| | |-- WiFi @ 1.0
| |-- ESPmDNS @ 1.0
| | |-- WiFi @ 1.0
| |-- FS @ 1.0
| |-- FTP @ 0.0.0+sha.f3521ff
| | |-- WiFi @ 1.0
| | |-- FS @ 1.0
| |-- Update @ 1.0
| |-- HTTPClient @ 1.2
| | |-- WiFi @ 1.0
| | |-- WiFiClientSecure @ 1.0
| | | |-- WiFi @ 1.0
| |-- WiFi @ 1.0
|-- EncButton
|-- TM1637 Driver @ 2.1.0
| |-- AsyncTCP @ 1.1.1
| |-- FS @ 1.0
| |-- WiFi @ 1.0
|-- iarduino RTC (часы реального времени) @ 1.3.4
| |-- Wire @ 1.0.1
|-- ESPAsyncE131-wled
| |-- WiFi @ 1.0
|-- arduinoFFT @ 1.9.1
Building in release mode
Compiling .pio/build/esp32/libfa7/FastLED/FastLED.cpp.o
Compiling .pio/build/esp32/libfa7/FastLED/bitswap.cpp.o
Compiling .pio/build/esp32/libfa7/FastLED/colorpalettes.cpp.o
Compiling .pio/build/esp32/libfa7/FastLED/colorutils.cpp.o
Compiling .pio/build/esp32/libfa7/FastLED/hsv2rgb.cpp.o
Compiling .pio/build/esp32/libfa7/FastLED/lib8tion.cpp.o
Compiling .pio/build/esp32/libfa7/FastLED/noise.cpp.o
Compiling .pio/build/esp32/libfa7/FastLED/platforms.cpp.o
Compiling .pio/build/esp32/libfa7/FastLED/platforms/esp/32/clockless_rmt_esp32.cpp.o
Compiling .pio/build/esp32/libfa7/FastLED/power_mgt.cpp.o
Compiling .pio/build/esp32/libfa7/FastLED/wiring.cpp.o
Compiling .pio/build/esp32/src/DS18B20.cpp.o
Compiling .pio/build/esp32/src/buttons.cpp.o
Compiling .pio/build/esp32/src/color_palette.cpp.o
Compiling .pio/build/esp32/src/effects.cpp.o
Compiling .pio/build/esp32/src/effectsmath.cpp.o
Compiling .pio/build/esp32/src/effectworker.cpp.o
Compiling .pio/build/esp32/src/enc.cpp.o
Compiling .pio/build/esp32/src/events.cpp.o
In file included from include/main.h:45:0,
from src/buttons.cpp:1:
.pio/libdeps/esp32/EmbUI/src/EmbUI.h:19:24: fatal error: LITTLEFS.h: No such file or directory
* Looking for LITTLEFS.h dependency? Check our library registry!
* CLI > platformio lib search "header:LITTLEFS.h"
* Web > https://registry.platformio.org/search?q=header:LITTLEFS.h
compilation terminated.
*** [.pio/build/esp32/src/buttons.cpp.o] Error 1
In file included from include/lamp.h:43:0,
from src/effects.cpp:38:
include/effectworker.h:45:22: fatal error: LittleFS.h: No such file or directory
* Looking for LittleFS.h dependency? Check our library registry!
* CLI > platformio lib search "header:LittleFS.h"
* Web > https://registry.platformio.org/search?q=header:LittleFS.h
*** [.pio/build/esp32/src/effects.cpp.o] Error 1
In file included from src/effectworker.cpp:37:0:
*** [.pio/build/esp32/src/effectworker.cpp.o] Error 1
from src/effectsmath.cpp:38:
*** [.pio/build/esp32/src/effectsmath.cpp.o] Error 1
src/events.cpp:3:22: fatal error: LittleFS.h: No such file or directory
*** [.pio/build/esp32/src/events.cpp.o] Error 1
In file included from .pio/libdeps/esp32/FastLED/src/FastLED.h:75:0,
from include/color_palette.h:8,
from src/color_palette.cpp:1:
.pio/libdeps/esp32/FastLED/src/fastspi.h:157:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
========================================================================= [FAILED] Took 42.30 seconds =========================================================================
Environment Status Duration
esp32 FAILED 00:00:42.304
==================================================================== 1 failed, 0 succeeded in 00:00:42.304 ====================================================================
